no high beam???? HELP
Old Nov 5, 2011 | 05:05 PM
sickboy75's Avatar
sickboy75
Default no high beam???? HELP
01 wide glide,itook headlight off to have to painted an when i hooked it up i have no high beam. I even tried another bulb. Its an aftermar,ket light. Its only two wires it worked fine when i installed it. Any ideas????
Old Nov 5, 2011 | 08:09 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Only two wires? There's no ground? I figure one to low, one to high and a ground for both. Maybe a ground to the headlight shell, or was the shell being the ground and now the paint is insulating the flow.
Old Nov 5, 2011 | 09:40 PM
sickboy75's Avatar
sickboy75
it is grounded in the shell. low beam works but when i switch to hi it shuts off
Old Nov 5, 2011 | 09:58 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Run the ground from the shell to something on the frame isntead. Maybe the tank bolt. That should solve your issue.
Drew
Old Nov 6, 2011 | 07:20 AM
8541hog's Avatar
8541hog
Maybe if you post some pics of the setup. If the low works it is not a ground issue, unless the high lamp is isolated.
You have 3 wires in the HD harness, which wires are you running to which lamp?
Dale_K
Electrical/Lighting/Alarm
Mar 5, 2016 07:42 PM
Mixter
Oct 27, 2015 03:24 AM
Veekness
Sep 29, 2014 07:26 AM
Bigstick
Sep 7, 2011 04:51 PM
Nautilus
Apr 4, 2010 04:02 PM
