Exhaust question...need torque cones?
AZrider is correct. The torque cones will help a lot with low to mid range performance. You need velocity in the exhaust as well as the right amount of back pressure to get best performance. The torque cones also give you an anti-reversion effect as well. Thank you, JR
I can also offer as evidence my own personal experience with torque cones, that mid range power was noticeably better when I installed them in my 1996 80 cubic inch Harley Davidson Low Rider with two inch drag pipes.
Don't mistake horsepower for torque, which is what I fear you are doing. You don't have to reach too far to determine that sticking a cork in the exhaust path might be harmful to redline horsepower ratings, but that sir is why they are called "torque cones", not horsepower cones. They work with the garden hose effect. Just like installing a nozzle on the end of a garden hose increases the waters velocity as it exists the hose, so does installing torque cone on a wide open exhaust. The improved exhaust velocity is essential in helping to create the lost low and midrange torque that open pipes create. Thats pretty much all I have...... defense rests.
___________________________
With the advent of the Twin Cam motors, the shape of the exhaust port was changed to a more "D" shaped port ... this feature had an anti-reversion effect minimizing the need for AR 'torque' cones with the Twin Cam motors ....
I think you are still well advised to utilize baffles with your pipes ....
R/
'Chop
Cons: too short and not equal length = poor design for optimum performance even with cones or baffles
Pros: look cool & probably sound cool
Id rock em WFO!
I feel like I need to chime in on the torque cone situation. Kenny Price invented the torque cones many years ago to help compensate for the lack of velocity in the large diameter pipes being made at the time. They do help develop 3-5 more torque after being installed. The by product of the torque cones was the anti reversionary effect they had on all pipes which help keep the exhaust pulse from re-entering back into the exhaust port. I have worked at Samson for many years so I know how they were developed. Torque cones were not in existence before Kenny made the first ones. If anyone needs proof on that look back in all the old catalogs and you will find they originated at Samson about 1994. Baffles are more effective than torque cones but torque cones are a good choice for bikes with pipes that do not accept baffles. Using both is best for open exhaust.
Thank you,
JR
Straight from Samsons website........
"are intended to provide the best performance"
"These pipes are the most dynamic and high performance aftermarket exhaust pipes ever built."
That sounds like marketing to me.
Even the Samson rep said in post #3 "The torque cones will help a lot with low to mid range performance" then he states in post #31 "They do help develop 3-5 more torque after being installed."
3-5 lbs or torque isn't a lot, it's a little...................
Same dyno on the same day on the same bike with no changes will produce results like that on paper.........
