Streached headlight options
Old Nov 16, 2011 | 10:56 PM
Nat_Asp_Mike's Avatar
Nat_Asp_Mike
Default Streached headlight options
I'd like to replace the stock FXDC headlight with a longer, chrome version.
I see many types of stretched headlamps, priced from low $$ to mid $$$.
Can someone recommend some brands, websites. Pics of bikes are really welcome.
Thanks in advance.
Mike
Old Nov 16, 2011 | 11:12 PM
xantasm's Avatar
xantasm
If your looking for like an adjure bullet style light there is a vendor on ebay named snappylights that sells new and for about half the cost of new seconds with small flaws in them you would probably never notice. I bought a flamed chrome 7" adjure bullet from them for $125 and I am really happy with it and I put a 7" LED lamp in it. The sell 5 3/4 inch and 7 inch as well as some others so they got a pretty good selection and I was pleased with delivery time, packaging, and price.
http://www.ebay.com/sch/Motorcycle-P...m1538&_vxp=mtr
If your stock light doesn't have the correct mount block for a bullet you can search around and probably find them on ebay as well like I did.
Old Nov 16, 2011 | 11:19 PM
Nat_Asp_Mike
Thanx for the info. Can I put my stock lamp into one of these buckets?
Old Nov 17, 2011 | 12:58 AM
xantasm's Avatar
xantasm
I am going to assume since you said its a stock FXDC light you have a 5 3/4 so as long as you get a 5 3/4 inch housing yes. You should be able to just disassemble your stock light parts and transfer them directly into the new bucket. The only thing you normally have to modify when changing housings is the wiring which you either have to carefully pull apart the stock plug and remove the wires and then put them into the new housing or cut them and splice them into a new plug. The adjure ones come with a generic wiring plug for H4 in case you need to cut and splice. Sounds complicated but its actually really easy, just make sure to try and keep your splice section inside of the housing so it has less chance of getting wet.
Old Nov 17, 2011 | 10:25 PM
Nat_Asp_Mike
Got it. Thanks again. I should be able to figure it out.
Old Nov 17, 2011 | 10:50 PM
bikerlaw's Avatar
bikerlaw
A lot of people on this forum recommended Eastern Performance. I choose to give them a try and am very happy. I went with the Cyclone. Its a good light. Once I installed a Silverstar bulb, it was actually a pretty good light thrower as well. Under a hundred bucks.
http://www.easternperformance.com/ca...hts-for-Harley
___________________________________
Old Nov 18, 2011 | 10:04 AM
dreamer65's Avatar
dreamer65
Old Nov 18, 2011 | 12:38 PM
Steel Steed's Avatar
Steel Steed
Let's see a side profile of you bike. In this pics, we can see the headlight, but lets see what it looks like on the bike. I'm looking for something kinda like that.
Old Nov 18, 2011 | 08:12 PM
bikerlaw's Avatar
bikerlaw
Old Nov 19, 2011 | 06:30 AM
wyldspirit's Avatar
wyldspirit
Headwinds Makes a couple of different models for your bike. http://www.headwinds.com/mm5/merchan..._Code=01010109
But all of their stuff is a bit pricey
