Streached headlight options
Old Nov 19, 2011 | 07:12 AM
bikerlaw's Avatar
bikerlaw
Same style headlight on my Shovel a couple years ago.
_____________________________
Old Nov 22, 2011 | 09:51 PM
Nat_Asp_Mike's Avatar
Nat_Asp_Mike
I appreciate all the suggestions. I ordered the Midwest Chrome Cobra II Headlight from easternperformance.com
I see that the OEM headlight has 3 wires; black, white and yellow. The new head light has 2 yellow and red.
Can someone help me out as to which ones get spliced together?
Thanks in advance
Mike
Old Nov 23, 2011 | 06:40 AM
bikerlaw's Avatar
bikerlaw
The missing wire is the ground wire as the light is internally grounded. Bolting it to the bike grounds it. I forgot which color is low and which is high, but a quick flip of the switch while holding the light will show you. Also, if you swap the light to a brighter bulb as I did, that front retaining ring actually unscrews. Its not pushed or popped in with clips, its threaded. It baffled me at first, but with advise from the forum, I figured it out.
Old Nov 23, 2011 | 07:43 AM
Baeseman1's Avatar
Baeseman1
Same light from the same place... I needed a longer mounting bar as this light is pretty long.
Also, I used the stock Harley light/lens with a Silverstar Ultra bulb. A direct fit, once I figured out the trim ring screws on.
Old Nov 23, 2011 | 11:59 AM
Frank Castle's Avatar
Frank Castle
bikerlaw that is one good lookin headlight.. probably gonna do something similar.. thanks for the pics..
Old Nov 23, 2011 | 12:42 PM
SuperglideKen's Avatar
SuperglideKen
You cant go wrong with this Headlight. The price is right and the quality is there. That SilverStar bulb is also another good idea. I have them in my ATV also.
Attached Thumbnails Streached headlight options-headlight.jpg   Streached headlight options-headlight2.jpg
Old Nov 23, 2011 | 03:44 PM
LDB187's Avatar
LDB187
Off topic a bit but is that coat rack an FXR?
Old Nov 23, 2011 | 11:49 PM
Nat_Asp_Mike
I love all the pics with the various lights. The headlamp I got fits without the bracket but I'm tempted to get a mounting bar to make it protrude like yours. I have similar drag bars so that's the look I was originally after.
I'll post pics after the weekend.
Thanks to everyone for helpful info.
Mike
Old Dec 22, 2011 | 09:53 PM
Nat_Asp_Mike
Here's what I ended up with.
acchd
Jul 31, 2017 11:19 AM
DCrider132
Aug 19, 2016 02:18 PM
steveg56
2014-2024 Touring Models
24
May 19, 2016 08:02 AM
zworld
May 23, 2012 10:35 AM
amish
Feb 1, 2008 05:20 PM
