Help needed ASAP
Old Nov 22, 2011 | 06:01 AM
wyldspirit's Avatar
wyldspirit
Default Help needed ASAP
I have a huge problem and thought I would turn to everyone here to get a quick solution. Here is the problem... I pick the bike up today and the only real place I have to store it is my shed... Building a new shop starting next week and I be dammed if I will leave the bike out in the weather. So I have the clearance to get the bike in the shed but I need a way to get it in there. I was planning on the ramps they sell at Lowes or Home Depot but after reading the reviews I don't really trust them. I was also looking at using plank 2x10x8 lumber but what would be the weight rating be on those? Like I said this is just temporary.
Old Nov 22, 2011 | 06:13 AM
dyna rider's Avatar
dyna rider
Default Ramps
You could buy 2-2x10x8s and lay them side by side and use strips of other wood to bind them together.
I think if it was me, I would just buy a piece of 3/4" plywood. If I remember the load bearing capacity of 3/4" correctly, it is 600pds per square foot. That is more than adequate to support your bike since that would be spread over the 2 wheels in contact area. You could also cut it in half and double the thickness.
Old Nov 22, 2011 | 06:16 AM
vtwinhd59's Avatar
vtwinhd59
How high is the shed off the ground. If its only a foot or so the ramp or lumber idea should work just fine. An atv ramp will hold the weight. The Plank Idea would be iffy. If I was going to go that route I'd at least support the underside of the plank with some kind of brace so it doesn't bow to much and break.
Old Nov 22, 2011 | 06:28 AM
bobnehoc's Avatar
bobnehoc
I keep my ride in a big shed on the side of my house. I have a ramp made out of pressure treated lumber. The shed is probably 6 or 8 inches off of the ground and I used 2X6 boards to construct it. Works fine and no problem with weight what so ever.Since this is only temporary I would put to or three 2X6 's togegher with a cross brace on the underside and keep the length of the ramp between 2 or 3 feet and you will be just fine.....
Old Nov 22, 2011 | 06:35 AM
wyldspirit's Avatar
wyldspirit
From the ground to the entryway is maybe 6 inchs high
Old Nov 22, 2011 | 06:36 AM
ricerocket71's Avatar
ricerocket71
Built a ramp for my shed to get the bike in and out
A. Took two 5 foot 2 x 10 cut them diagonally corner to corner.
B. Use a another 5 foot 2 x 10 nailed it to the back of cut 2x 10
(this is the width of shed door opening) and supports the deck against the shed
C. and then just got some 5/4 X 6 X 10 Pressure treated decking and screwed them to the cut 2 x 10's
Had everything pre-cut at local home depot and it took all about 30 minutes to put in place
Hope this helps you out
Old Nov 22, 2011 | 06:38 AM
ricerocket71
Sorry double posted
Old Nov 22, 2011 | 08:47 AM
ackman1968's Avatar
ackman1968
Originally Posted by ricerocket71
Sorry double posted
That's been happening a lot. My computer will sit like it stalled and then I get the double post. Between that and the search issues they must be having problems again.
Old Nov 22, 2011 | 09:07 AM
misfitJason's Avatar
misfitJason
Really. This is a huge problem? Ok the best solution is to weld a metal ramp with triangular support sides and use a grating for the run way.
Old Nov 22, 2011 | 09:09 AM
mrnone's Avatar
mrnone
get 3 guys and 2 strong poles
one pole through each wheel one guy on each end of the pole spend the lumber money on beer
