Exhaust Gasket question
Old Dec 2, 2011 | 11:26 AM
shrini23's Avatar
shrini23
Default Exhaust Gasket question
Guys pretty minor question
I'm removing my V&H big radius 2-1 pipe and doing some cosmetic change to the engine part...
Afterwards i'll put back the pipes...
My question...Can I reuse those exhaust gaskets or everytime I remove the exhaust should I have to replace with a new one?
Old Dec 2, 2011 | 11:36 AM
Scuba10jdl's Avatar
Scuba10jdl
Some people have had great success reusing them. I prefer to always use new ones. It's relatively cheap and those crush gaskets don't always fit back in the same way.
Old Dec 2, 2011 | 11:39 AM
soft 02's Avatar
soft 02
Ive gone through 3 exoust sets and removed them many times only using the factory original gaskets. 4 years and 98,000 miles. Probably saved enough for a few cases of beer by now. Worked for me.
Old Dec 2, 2011 | 12:17 PM
nevil's Avatar
nevil
New gaskets are not that costly. You can probably get away with leaving the old ones in with no problems. The last time I removed my exhaust I just put new ones in for the peace of mind. The pipes had been on and off three times before and didn't leak.
Old Dec 2, 2011 | 01:00 PM
Harley Tim's Avatar
Harley Tim
If you are using the SE gaskets.... replace them.
If you are using the stock gaskets.... use again.
Hope this helps
best wishes....Tim(HT)
Old Dec 2, 2011 | 01:11 PM
8541hog's Avatar
8541hog
Some do apparently with success, but I always ask 2 questions when thinking about reusing gaskets...
If it does leak how much of a pain will it be to replace them? What is your time worth?
Personally I do not think it is worth it.
Old Dec 2, 2011 | 05:34 PM
bigbully67's Avatar
bigbully67
I have had my exhaust off 3 times with the original gaskets and have had no problems. I always take a good look at them before mounting my pipes to see if they have been damaged or compressed into the exhaust port. If all looks good, I run with them.
sac130e
Dec 18, 2015 02:59 PM
Ricketts
Oct 16, 2014 10:32 PM
Landcruiser
Exhaust System Topics
Aug 18, 2014 11:56 PM
arejay86
Oct 3, 2012 08:50 AM
das56170
Mar 26, 2010 12:07 AM
