Front judders when braking?
Old Dec 4, 2011 | 07:46 AM
Scouser1's Avatar
Scouser1
Default Front judders when braking?
I have a 2006 Dyna fxd35, I have recently noticed that when I brake for the first half a dozen times the front end really judders?
Then it seems to disapear ?
It's only done about 6000 miles.
Any ideas?
Someone has mentioned that there was a recall to fit a thicker washer under the main nut in the middle of the triple tree, anyone else heard of this?
Thanks
Scouser
Old Dec 4, 2011 | 12:08 PM
hell hound's Avatar
hell hound
there was a problem with that year with a spacer in the neck
they also increased the recommended torque on the nut
If you have a jack lift up the bike and strap it down real good
then grap hold of the front wheel and lift it up and press it down
if there is movement that way in the neck and it sort of pops then you have a problem in the neck.
Also if the wheel is straight ahead and you can tap it real lightly and it flops to the side you may only have to tighten down the tension. and this test works best with the bike level on the lift and with the clutch cable unhooked from the handle bars
Old Dec 4, 2011 | 02:41 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Check your front tire for any abnormal wear and correct recommended tire pressure. Sometimes the front brake pads while develop a little hum or something when they are pressed against the disc/rotor vent holes.
Old Dec 4, 2011 | 02:46 PM
tkunk's Avatar
tkunk
My road glide rotors warped right away. Maybe that's it. Is it a shimmy like that?
Old Dec 4, 2011 | 02:52 PM
editbrain's Avatar
editbrain
When it was time for me to change my front tire I could tell that using the front break would cause a little stutter.
Actually all the suggested remedies or causes are valid in this thread.
Old Dec 4, 2011 | 04:11 PM
Scouser1's Avatar
Scouser1
The strange thing is it only happens when I first go for a ride, its as though when the brake is warm it stops?
I have fitted Lyndall pads and the rest is stock, the first time I use the front brake it really judders, then gets less noticable with each application of the brake then after I have used the brake about a dozen times the judder disapears?
Scouser
Old Dec 4, 2011 | 04:19 PM
editbrain's Avatar
editbrain
Maybe when you changed the pads you got air in the lines.
Old Dec 4, 2011 | 04:26 PM
dyna rider's Avatar
dyna rider
Default Front Brake
Live in a high humidity area ? Could just be damp pads...
Old Dec 4, 2011 | 05:54 PM
Scouser1's Avatar
Scouser1
No air in the line and it's not that humid here ?
It's as if it goes away once the pads or disc gets a bit warm?
Scouser
Old Dec 4, 2011 | 06:07 PM
editbrain's Avatar
editbrain
I put Lyndall pads on the last time I changed my break pads. Not the gold, but the others. I cannot remember the model # or name.
I like that they do not dust up the wheels, but they are not my favorite break pad for stopping. I am finding that out. I don't know what I will put in next, but it will not be Harley labeled break pads or Lyndall break pads.
I hope you figure it out. Your front breaks are very important, and I'd had to see them fail instead of working during a ride. Good luck to you.
Crueltiming
Jun 4, 2015 11:07 AM
jaybob1807
Sep 23, 2013 05:52 PM
Swilkins
Apr 21, 2011 01:42 PM
albngore
Feb 14, 2011 08:44 AM
dmaxey
May 25, 2009 01:17 PM
