Help needed: Handle bar wiring question
Old Dec 7, 2011 | 10:28 AM
8541hog's Avatar
8541hog
Originally Posted by DSnoopy
Just looking for this this morning. Do I have to lift the tank up to access the connectors?
I don't on mine, but you can get by with just unbolting the front bolts and lifting it an inch if need be. Just watch out for the crossover fuel line.
Old Dec 7, 2011 | 10:29 AM
8541hog's Avatar
8541hog
BTW, you will find a black plastic cover on the frame, remove that cover and you should see the wires folded back inside the frame. Just work them out.
Old Dec 7, 2011 | 11:18 AM
DSnoopy's Avatar
DSnoopy
Thanks again!
Old Dec 7, 2011 | 12:31 PM
HD Bobber's Avatar
HD Bobber
Originally Posted by SURFOR Chop
Not sure why you cut the wires ... not sure about your Street Bob, but my '05 FXDI Super Glide there's a 6-pin AMP plug that you would just unplug ... pull the wiring from the handlebars and then re-route it to where you're moving the sigs ....
But, if you cut the wires, I suppose at this point you'll just need to splice and run the turn sig wires to your new setup ....
R/
'Chop
+1
All I did was pull the pins from the connectors.
Old Dec 7, 2011 | 01:38 PM
DSnoopy's Avatar
DSnoopy
Thanks, I'll look for the connectors when I get home tonight.
jmerchant.1
Jul 2, 2014 11:44 PM
Boozefighter Borracho
Nov 3, 2010 07:27 PM
SigEpRider
Apr 18, 2009 05:04 PM
rubiconMike
Aug 29, 2008 07:44 PM
jrsmith_80
Apr 1, 2008 11:34 AM
