Performance filter install question?
Old Dec 12, 2011 | 02:29 PM
JADAMS12982's Avatar
JADAMS12982
Default Performance filter install question?
So my winter project was a screming eagle heavy breather and pcv. when i put the new sehb on there is a plug in the back of the stock air cleaner. what do you do with it as there is no where to plug it in now?
Old Dec 12, 2011 | 02:43 PM
rooti's Avatar
rooti
That plug doesn't do anything, I think it may be used in Europe or something like that. Just tuck it in and cable tie it to something and your good to go.
Old Dec 12, 2011 | 03:18 PM
bobnehoc's Avatar
bobnehoc
Like rooti said, don't worry about the plug. It is not used on our bikes. Just tuck ut away and forget about it.....
Old Dec 12, 2011 | 05:04 PM
TGWN's Avatar
TGWN
Looking at doing the same thing. Good info for when I start. Thanks.
JADAMS12982
thanks guys
Old Dec 14, 2011 | 01:38 PM
James_Johnston's Avatar
James_Johnston
Former Sponsor
Harley uses the same wiring harness on the US bikes and the UK bikes. That plug is used for a sensor for bikes set for the UK and other places like Australia. Those bikes have what is called an AES or active exhaust system, it was introduced in the UK in 2007 and is a computer controlled motor that opens and closes a valve in the exhaust; it was added to meet the noise requirements in Europe. If you are in North America, it is not used or connected to anything, so just use a twist tie to secure that pigtail off somewhere.
charger426
Aug 26, 2015 08:25 AM
Rubline
Apr 4, 2015 01:53 PM
PikeAl
May 27, 2014 09:47 PM
James K
Apr 29, 2012 12:40 PM
treborhunt
Jul 3, 2009 03:14 AM
