Powder-coating lower fork and triple trees
Old Dec 28, 2011 | 04:57 PM
p51bombay's Avatar
p51bombay
I ordered the 12mm from snap on (brand ***** - LOL) but if you can't find a longer one just make sure the bit is removable, then cut off a L key and insert it into the socket. It doesn't matter if it falls out after.
Old Dec 28, 2011 | 05:21 PM
Dropkick's Avatar
Dropkick
Awesome this thread came up. I just got a quote for powder coating my front end. Already have my service manual and those tools in my garage. I have that same jack. I used it when I installed forward controls. I didn't use a frame adapter, just used the tie downs to make sure she couldn't go anywhere.
The manual says for dis-assembly, "clamp fork tube in FORK HOLDING TOOL (part no. HD-41177) and mount in vise. Is that really necessary? I'm thinking I can make my own.
Good luck with your project low r1d3r.
Old Dec 28, 2011 | 06:20 PM
p51bombay's Avatar
p51bombay
You have a fork holding tool already, its called the triple clamp on your bike.
Loosen the top triple clamp pinch bolts but leave the bottom ones tight.
Remove the stem nut and the top clamp ( you don't have to but it gives more room to work)
LOOSEN but do not remove the top cap nut.
Using your impact wrench, now remove that 12mm allen holding then slider on.
Now remove that top cap nut while the lower triple clamp holds the tube, once that is out then remove and fully dissassemble the tube.
On reassembly use that lower triple clamp at appropriate times to hold the tube - makes life much easier, especially while reinstalling that top cap nut.......with the tube clamped low enough to where you can get above it and put your weight on the ratchet all you need to do is spin it with your other hand and it will thread right on.
What I did was assemble the fork without oil using the spring to hold the damper rod, remove the cap and spring, add oil and reinstall the spring and cap.
Old Dec 28, 2011 | 06:30 PM
Jeff W's Avatar
Jeff W
Long butted 12mm Allen socket, I ended up with the short one and ground the socket part down until it fit up in the hole, breaker bar and hammer knocked it right loose with a bud holding it, no vice needed.
It's an easy job, just lay everything out in order as they come out, then it's just a matter of reversing going back.
Old Dec 28, 2011 | 07:33 PM
dynabobster's Avatar
dynabobster
Originally Posted by L0W R1D3R
What did Santa leave under the tree for me? A Craftsman yellow motorcycle jack! http://www.sears.com/shc/s/p_10153_1...2&blockType=G2
Are there any special tools needed other than a ridiculously large socket to open the top of the forks?
The Sears Yellow jack is a PITA to use so do yourself a favor and return the Yellow jack and exchange it for the Red jack then do the SC Mod https://www.hdforums.com/forum/dyna-...ification.html to move the lift pads to the outside of the lift arms. Same can be done with the MC Jack Harbor Freight sells and you do not have to cut the center bar out. HF jack on sale for 59.99 coupon code 31790191 and they should honor the code at the store.
http://www.harborfreight.com/media/c...mage_14601.jpg
Get your self the the special socket for the fork caps.
http://www.mbsmfg.com/hafocapnutso.html
If you are removing the triples you are going to have to access the electrical connectors in the frame just in front of the tank, best to remove the tank and get it out of the way so you don't damage it.
A how to I posted a while back
https://www.hdforums.com/forum/8685048-post12.html
Old Dec 29, 2011 | 10:13 AM
Ganooch's Avatar
Ganooch
Originally Posted by p51bombay
Spend another $50 at Sears (before they close it) for a 3/8" butteryfly impact wrench and a 12mm socket wrench - it will make getting the sliders off much easier, in fact, you can do the job without ever removing the spring from the tube.
Powder-coating the lowers, so springs need to come out. I already have a 12mm socket and a hefty, long as hell, torque wrench. Don't think I am going to throw down for an impact just yet. Maybe after I get a good air compressor...
Old Dec 29, 2011 | 10:18 AM
Ganooch's Avatar
Ganooch
Awesome how-to. There seems to be a little more to this than I bargained for. I followed everything except the clean, dry and repack bearings. Is there a special tool needed? Can the bearings remain assembled?
Old Dec 29, 2011 | 10:22 AM
Ganooch's Avatar
Ganooch
Also, I ordered the fork cap socket just now. Thanks for the link.
Old Dec 29, 2011 | 11:07 AM
ryderbiker's Avatar
ryderbiker
I wasted a lot of gas and time trying to find an allen socket that would work. I'm glad to see I wasn't the only one.
BillHarley
Oct 29, 2019 09:24 PM
cmshdfx4
Sep 19, 2015 04:37 AM
travism173
Mar 31, 2014 11:54 AM
jgcable
Dec 23, 2013 10:59 PM
Alpal
Oct 1, 2013 01:31 AM
