Headlight swap questions
I bought a 7" DBI headlight bucket with sealed beam bulb on eBay and when I got it I found there are 5 wires inside and unlike the stock FXD bucket.
I've read in other posts that the extra wires are intended to hook up passing lamps. Even though I probably never will, I may as well leave them in there if I can... Can I? If not what is the best way to go about making the swap. I know there have been threads on this, but after searching for the past two days, I can't seem to find one that makes it clear enough and I don't want to waste a bunch of fuses trying to figure it out if I don't have to.
Can anyone shed a little light on this? Pun intended.
You need 3 wires for a stock setup, ground, high and low, if the other 2 are for passing lamps you can just put some heat shrink on the ends of the wires to insulate and keep from shorting.
Are these wires inside the bucket or out in a connector?
I have no harness attached and was planning to use the stock one if possible. The wires consist of a bound set that has YELLOW, WHITE, one THICK BLACK and one THIN BLACK wires, along with a single unbound YELLOW with a spade clip termination. From looking inside, it seems like I have running and/or low beam which are YELLOW, high beam is WHITE, and ground is BLACK. Does this seem correct? What I am still unclear of, is will there be an issue with leaving the spade end YELLOW, as it's out side of the bucket? I figure if I have to, I can cut it off with a small lead inside the bucket, then heat shrink or otherwise insulate it so that I still have it for later use if needed. But will it be safer to just remove it all together?
From the pictures, you can see the THIN BLACK comes into the bucket and is riveted on as a ground, then loops back to the bulb, but the THICK BLACK runs directly to the bulb. Is the THIN BLACK intended for running light ground? And how should I terminate this wire if I have no running lights?
If what I have gathered is correct, then would I just attach the wires to the wiring harness as follows: W>2, bound Y>3, thick B>4, and then, what to do with the extra two wires (spade yellow and thin black)?
Again, thanks for your time and any help you guys can offer!
The White, Yellow and Black (thick) should be the ones you need.
Try connecting to your bikes harness/connector and see if it works properly.
The spade yellow should be able to be clipped and pulled back into the bucket and insulated. Same with the thin black.
If you still have your stock headlight, you can either clip the connector off with enough lead to solder to the new wires, or disassemble the connector and get new pins for the new wires.
Let me know if this makes sense, should be pretty straight forward.
Thanks for the info, it took some of the uncertainty out of the job.
I'm going to post a walk through with pictures so if in the future anyone comes along like myself, they won't have as many questions about it going in. It's about time I can contribute to the forums, rather than just sponging information from everyone!
Cheers,
Jimmy
Cheers,
Jimmy
Thanks.
But I had to chuckle at this ...
