Flat Rear Tire
Old Jan 4, 2012 | 10:21 AM
EricInNCa's Avatar
EricInNCa
Default Flat Rear Tire
So I take a ride over the holidays and the next day I go out to the garage and my rear tire is flat. It seems I picked up a screw somewhere. The tire has less than a 1000 miles on it. Dealer won't fix/plug the tire because of the liability. Local tire shop won't repair/plug the tire, again liability issues. Am I screwed (no pun intended) and have to buy a new tire or should I opt for putting a tube in???
Old Jan 4, 2012 | 10:35 AM
HOGRIDA_06's Avatar
HOGRIDA_06
I'd take my chances and and plug it and run a tube.
Old Jan 4, 2012 | 10:41 AM
rob_will's Avatar
rob_will
that happened to me once...
I pulled the tire off patched the inside of the tire then ran a heavy duty tube.....
Lasted for about another 7000 miles....which was normal since I already had about 4000 miles on it.
Old Jan 4, 2012 | 11:11 AM
Fridge's Avatar
Fridge
It's smack bang in the middle of the tyre, perfectly fine to repair.
If you can't find a shop that will repair it then yea, bung a tube in!
Old Jan 4, 2012 | 11:24 AM
will227457's Avatar
will227457
id plug it and forget about it
Old Jan 4, 2012 | 11:29 AM
art0565's Avatar
art0565
Plug it, you'll fine
Old Jan 4, 2012 | 11:36 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Never had a problem personally but my buddy lost a plug on his rear tire on the way to Laughlin this year. He was riding right in front of me at 80 on the freeway with his girlfriend on the back. It was quite freaky. I used to always advise to patch it but after seeing that I say get a new tire.
Drew
Old Jan 4, 2012 | 11:49 AM
vet767's Avatar
vet767
A patch and a tube I might go for but not a plug. Plugs have been known to fail to do their job and it's bad enough in a car tire. I had a rear tire go at speed many years ago and never want to do it again, but then it's your butt not mine.
Old Jan 4, 2012 | 11:54 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Never had a plug come out but had two leak (in cars) Too risky for a leak on a bike. Time you pay some one to patch (inside) and tube you may as well get a new tire. Do not plug and tube. If you stay local, go slow and look before you drive every time you can plug but that's really not possible and a pain. I would replace it.
Old Jan 4, 2012 | 12:10 PM
07bobber's Avatar
07bobber
Patch it and tube it, cheaper than a new tire and safer than a plug
