Coil Relocation
Old Jan 13, 2012 | 10:37 PM
  #31
kilrain's Avatar
kilrain
This what it looks like before the tank lift:
Old Jan 14, 2012 | 12:07 AM
  #32
luther's Avatar
luther
6th Gear
Sweet!!!
Old Jan 14, 2012 | 12:12 AM
  #33
ryderbiker's Avatar
ryderbiker
I think the wires should be a bit longer. They look stretched.
  #34
luther's Avatar
luther
6th Gear
Originally Posted by DK Custom
Delphi makes the male side of the plug. Most electronic parts houses either have it or can order it.
If you are looking for the female side of the plug, NO ONE makes them. The only place you can find them is built into the coil. When we were designing our Coil Relo we wanted to use the same plugs for the wire extension, but found out that the female side simply does not exist. Delphi will make them special....minimum order is 10,000 units!!!
Yep, thanks, just lookin for the pigtail to plug into the coil. Guess I'll need to do a little more homework.
Old Jan 14, 2012 | 12:20 AM
  #35
kilrain's Avatar
kilrain
Thumbs up
This was right at the initial installation and although they look stretched, they aren't. They are EXACTLY the right length best I can tell. Since the coil is not mounted to the motor, movement caused by torque is a non-issue.
That being said, their other wire option is a bit longer and may suit your taste better.
Old Jan 14, 2012 | 12:39 AM
  #36
ryderbiker's Avatar
ryderbiker
I've got red SE wires on my bike now and I'm planning to order the same with the relocation kit.
Old Jan 15, 2012 | 12:53 PM
  #37
blueangel73's Avatar
blueangel73
Originally Posted by 07bobber
this is a cool mod but i dont like how theres an empty spot in front of the fuse cover now....
This is exactly what I like about this kit and It has been added to my list. The reason I like this is because it helps me solve one more issue with running a tru-dual exhaust setup, now I can make a pipe that can exit through this area, like it does on the softies.
Old Jan 15, 2012 | 01:15 PM
  #38
CBRAV0810's Avatar
CBRAV0810
Thanks for the response and info, I'll have to add this to my list.
Old Apr 16, 2012 | 12:23 PM
  #39
Le Vizir's Avatar
Le Vizir
I just ordered one complete relocation kit today ! I can't wait to have it ^^
Old Apr 16, 2012 | 04:50 PM
  #40
BlueFlameWG's Avatar
BlueFlameWG
Have had this one on my list since for a bit. Will be ordering soon.
Kevin is their any way yall do blue wires. kits on site only specify red and black?
