Coil Relocation
Old Jan 8, 2012 | 03:57 AM
nkauf21's Avatar
nkauf21
Default Coil Relocation
I happened to see this coil relocation kit from DK Custom Products so I decide to go for it. http://www.dkcustomproducts.com/99-1...n-Kits_c52.htm I think it will look pretty slick. I got the premium kit that comes with the proper length SE wires in red and a horn that relocates to the front of the frame. I had already relocated my horn but used some crappy ebay special that you can't even hear when the bike is running so hopefully this one will be a little louder.
Just ordered it so once it arrives and I install it I'll post up some pics.
Old Jan 8, 2012 | 08:29 AM
Robbie13's Avatar
Robbie13
LOSER
Pretty cool. Post some pics when you are done.
Old Jan 8, 2012 | 08:39 AM
crimson13's Avatar
crimson13
Default You will like
I got one and like it the only negative thing to me about it was how you extend your harness I would rather solder but each their own,it does look slick Here some pics of mine with the taylor race wires,(i am changing to screaming eagle black)
Attached Thumbnails Coil Relocation-dsc00374.jpg   Coil Relocation-dsc00372.jpg   Coil Relocation-dsc00373.jpg
Old Jan 8, 2012 | 09:57 AM
nkauf21's Avatar
nkauf21
How exactly do you extend the harness?
Old Jan 8, 2012 | 10:45 AM
crimson13's Avatar
crimson13
did you see that long black wiring harness in the kit you ordered? You cut the wires goin to the coil then put male end on the ends comng from the main,then plug the long black wiring harness up then route it under the tank and down to new coil location. then put a female end on the coil plug,you end up with 3 connections It is alot easier and more secure in my opinion to cut an solder and use heat shrink to extend the coil harnesswhich only leaves you with one connection. imo I did not like the way instructions has it done , like I said there is nothing wrong with it I just didn't like it personal opinion. You will like the coil relocate it is worth the effort and DK customs are really cool great customer service
Old Jan 8, 2012 | 11:02 AM
nkauf21's Avatar
nkauf21
Yeah, I saw it and knew that it had to be extended. There just wasn't a lot of info on how to do it. Thanks for the info.
Old Jan 8, 2012 | 12:52 PM
crimson13's Avatar
crimson13
No problem at all good luck with it let me know if I could help you post ppics when your done
Old Jan 8, 2012 | 01:06 PM
ryderbiker's Avatar
ryderbiker
Thanks for posting this, it's on the winter mod list now.
Old Jan 8, 2012 | 01:43 PM
CBRAV0810's Avatar
CBRAV0810
Difficult install or pretty straightforward?
Old Jan 8, 2012 | 02:19 PM
crimson13's Avatar
crimson13
Its straight forward really easy
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
