Coil Relocation
Old Jan 8, 2012 | 02:19 PM
KungPowMinchow's Avatar
KungPowMinchow
another winter time mod to add to the list....and just to think i was almost done with them this year
Old Jan 8, 2012 | 07:58 PM
ryderbiker's Avatar
ryderbiker
I haven't even started on mine. I'm waitin on the tax return. It's all spent already.
Old Jan 8, 2012 | 09:23 PM
crimson13's Avatar
crimson13
mine too on slotted six spoke wheels can't wait
Old Jan 9, 2012 | 01:45 PM
07bobber's Avatar
07bobber
this is a cool mod but i dont like how theres an empty spot in front of the fuse cover now....
Old Jan 9, 2012 | 01:57 PM
Redbeard's Avatar
Redbeard
It's a very clean look, but I wonder if the coil is now subjected to excessive vibration...
Old Jan 9, 2012 | 05:25 PM
FBFletch's Avatar
FBFletch
Recently finished a coil relo on my Fat Boy using the DK Customs kit.
Didn't much care for the wiring harness provided. I thought the connectors were too bulky. Instead, I just extened my harness by soldering extensions into the harness and heat shrinking over the solder connections.
I also decided to do my own thing with the wires. So, I got the kit without wires. I ordered a set of 8" wires from Taylor. Due to the offset of the plugs on the coil, the rear cylinder wire is almost too short. It works but it's a stretch. So, I called Taylor today had they're custom making me a 9.5" wire for the rear cylinder.
The coil mounting bolts that came with the DK kit were too long. The stock bolts were really too short. So, I took the bolts that came with the DK kit, cut them to the length I needed (with the nuts installed on the bolts), and cleaned up the threads by running the nuts on and off a couple of times and removed any burrs with the wire wheel on the grinder.
I know the relo won't be exactly the same for you folks with Dynas but, I thought you might find some useful info here.
Old Jan 9, 2012 | 07:22 PM
ryderbiker's Avatar
ryderbiker
I don't think I've ever gotten a part that installed the way it should. I think I've spent $500 buying new bolts and other crap to make things work.
Old Jan 9, 2012 | 10:27 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Hey Fletch,
We are always looking to improve. How much too long were the bolts?
Would be interested in knowing how much Taylor charged you for the pair of 8" wires, and what the charge is for the 9.5" wire.
No doubt it is cleaner to solder the extensions in, the waterproof connectors are for convenience for many not comfortable with soldering.
Thanks!
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Jan 9, 2012 | 11:20 PM
ryderbiker's Avatar
ryderbiker
Hey Kevin do you offer a discount for HDforums members or Military?
Old Jan 9, 2012 | 11:49 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
We periodically run specials on the forum...right now we are running one on the Triple Trap Pegs....see link below.
