Battery Post Connection Problem
Old Jan 12, 2012 | 04:13 PM
Austin Dave's Avatar
Austin Dave
Default Battery Post Connection Problem
Bought a Drag Specialties battery to replace OE unit. Ran into problem with post connection. No steel threads in the new batt. Have not run into this before. Fix? Thanks
Attached Thumbnails Battery Post Connection Problem-batt-connection-004.jpg   Battery Post Connection Problem-batt-connection-005.jpg
Old Jan 12, 2012 | 04:25 PM
Robbie13's Avatar
Robbie13
LOSER
There should be some square nuts to fit inside the posts.
Old Jan 12, 2012 | 04:58 PM
Austin Dave
Did some checking. There is supposed to be a post kit included in the box....it was not. Bought the batt a few months back as a 'just in case' purchase. Never thought about the kit missing. Batt in the box and on the shelf until Sunday. Will figure something out.
Old Jan 12, 2012 | 05:01 PM
Robbie13's Avatar
Robbie13
LOSER
I haven't had to remove my battery yet. Check to see if the stock battery is threaded or the nut are just stuck on the posts.
Old Jan 12, 2012 | 08:03 PM
Austin Dave
All better now.
Old Jan 13, 2012 | 06:55 AM
Robbie13's Avatar
Robbie13
LOSER
So, what did you find?
Old Jan 13, 2012 | 07:04 AM
Austin Dave
Used some spring-nuts I had from the olden-days when I was a working man. Pulled the springs off and cut-down the nut bodies to fit inside the battery post entrances. Drilled out the threads for use as front spacers and tapped the inner nuts to fit the attaching bolts. Slathered posts with vasoline the used Blue thread-locker on bolts. Good to go.
btw: stock Harley battery has 'made' posts with steel-threaded nuts in the lead post attachment. Could possibly remove those from the circular battery post with heat because I believe they are soldered on, but an iffy thing at best.
Old Jan 13, 2012 | 07:08 AM
Robbie13's Avatar
Robbie13
LOSER
Sweet!
Whiskyjock
Jul 3, 2018 01:46 PM
SwiftyBKells
Mar 11, 2013 05:47 AM
Jbo24
Mar 30, 2010 03:37 PM
mississippiboy
Dec 12, 2008 08:42 AM
stubby
Sep 18, 2006 10:45 AM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
