HELP!!!!!!!! ECM Upgrade
Old Jan 28, 2012 | 07:23 PM
Doc Richmond's Avatar
Doc Richmond
5th Gear
Default HELP!!!!!!!! ECM Upgrade
I started today on my 2010 Street Bob upgrade. I put on the V&H V02 Naked Intake, and then the Bub Sidecutters 2 into 2 pipes, with a startup of the bike after every mod. Soso after the aircleaner, big jump after the pipes. THEN, I added a PC III from Fuel Moto. And now, it will not turn over and just seems to drain the battery. Is it not programed, could it be another problem? Also, for some reason, now when its in gear with the clutch pulled in. it won't roll. Is it related, or am I just crazy? Help!!!!!!
Old Jan 29, 2012 | 05:27 PM
monkeyboy22's Avatar
monkeyboy22
First thing I'd do is take the PC III off and see if the bike starts without it. If that works I'd then take a look at what "map" has been loaded into it. It might also be the result of a defective PC III. Rare but, it does happen. As far as not rolling in gear, the clutch plated are probably still engaged a little bit. The two problems you are having are not related.
Therealrsp Therealrsp Therealrsp
Mar 11, 2016 06:29 PM
Toe Knee
May 2, 2010 07:29 PM
littlejake
Apr 8, 2010 02:12 PM
hddave2
May 12, 2008 02:24 PM
pfd161
Jun 13, 2007 10:08 AM
