Red Key - after install LED rearlight , and removed front indicators
WADR, FenceSC is incorrect... The problem with the key icon is in fact load. It has nothing to do with the front turn signals being two wire or three wire. (BTW, front turn signals have been three wire since they came out in 1973. 1157 bulb to do run and turn functions.)
When you removed the front signals, the current draw was cut in half, so the TSM (or TSSM or HFSM) system sets a trouble code. The trouble code is reported by the key icon... Same exact thing as happens when you switch to LEDs.
You need a Load Equalizer. Talk to Dan at Badlands, been working with the dude for years, he is a freakin' genius at this stuff...
Thank you! This is exactly what I said in the very first reply in this topic. I didn't want to reply back and start a back/forth with anybody over it since I have officially not installed a Badlands Load Equalizer to resolve the issue myself but I was pretty sure it was all load related.
I believe you misunderstood the gist of my post. Whether the turn indicators are 2 or 3 wire was not the relevant point. I was explaining that when I replaced the OEM 3 wire signals with 2 wire indicators, I left one wire, purple, disconnected. This wire runs through the security module and leaves an open circuit, leaving me with the key symbol lit. I was also confirming that it would not hurt to run the bike with the symbol lit. A load equalizer has stopped my signals from blinking fast, however the key remains lit because there is still an open circuit.
I use hand signals all the time too I wanted to remove the rear signals but that warning light comes one and it bothered me. For some reason my bike doesn't care about the front signals. I was able to clear that code and it never came back. I wonder what I could do if I didn't want to run any rear signals about that light short of putting a piece of tape over the light.
I have now confirmed that the signals operate at normal speed and the Red key light does go out with the Badlands Load Equalizer installed.
I just installed Badlands LE-03-A on Thursday night. I run an LED sidemount brake light and LED rear signals (wired as brake/turns not running) and I have no front signals. This is on my 2010 Street Bob. No more red key light or hyperflash.
Ok. I'll go to school here. I would like to know what is different from what I have done.
1. When you removed the front sigs, did you simply disconnect at the harness?
2. Are your rear sigs two or three wire? If two, what did you do with the purple wire?
I have installed a load equalizer and it eliminates the fast blink but doesn't eliminate the red key. Both front and rear LED sigs on my bike are two wire, and I simply taped off the purple wire.
1) My front signals are disconnected at the harness, in the frame under the tank. I did this while the frontend was completely disassembled last winter.
2) This is where you may be mixing things up. My rear sigs are 3 wires. (Batt+, Ground, Running) My rear LED sigs are wired with 2 wires so they only work as brake lights and turn signals. The 3rd wire is for the running lights, which I do not use, so I cut them and used heat shrink on them to prevent a short because, obviously, the 3rd wire is live while the ignition is on.
You should try the Badlands Load Equalizer. On my bike it was plug-n-play. No cutting, splicing, etc. I had it fully installed in 35 seconds, start to finish. I went out riding yesterday and I don't normally use turn signals but I did on purpose extensively trying to get some hyperflash and red key light. Neither occurred on my bike.
