help! need to buy replacement heat shields
Old Feb 14, 2012 | 07:26 PM
KungPowMinchow's Avatar
KungPowMinchow
Default help! need to buy replacement heat shields
Well i have a set of vance & hines big black radius 2 in 2. today i was out riding and low and behold the rear cylinder rear shield fell off and got ran over. well it turns out one of the hose clamps broke the mounting bracket and the other one sawed through braket. does anyone know where i can replacement shields on the net or do i have to call n order them from vance & hines direct?
Old Feb 14, 2012 | 09:15 PM
arkstreetbob's Avatar
arkstreetbob
Call V&H. Tell them what happened and they may cut you a deal. They are very good to work with.
Old Feb 14, 2012 | 09:24 PM
Mike650's Avatar
Mike650
^ Call them. they may just ask for your shipping address and send one free of charge.
Old Feb 14, 2012 | 09:28 PM
pontiac69's Avatar
pontiac69
I called v&h last year to see about getting a set of black heat shields. They wanted 300 plus for shields alone. I told them the pipes with shields are 400. I asked if they sell blems or scratched ones cheaper and they said no. Hope u have better luck.
Old Feb 14, 2012 | 09:34 PM
KungPowMinchow
ill give em a call tomorrow. hopefully it wont be over a hundred dollars but knowing my luck it will be and i have a feeling that the chrome tip insert is gonna be a seperate part number as well.
Old Feb 14, 2012 | 10:44 PM
grubeda7's Avatar
grubeda7
Ive gone through them and they are VERY helpful. Each one of them cost like $103 so if you only need one its not that bad. The guys at V and H have always been coo lto me and they might cut you a break. Good luck. And I might have an extra, I'll check the garage in the morning.
cliffyleft
Oct 28, 2021 07:21 PM
discosucks
May 22, 2011 02:56 PM
madchemist24
Apr 24, 2011 10:22 PM
vertical700
Mar 8, 2011 05:40 PM
jordanball33
Jan 28, 2009 09:34 PM
