battry life
Old Feb 15, 2012 | 12:44 AM
markkoby's Avatar
markkoby
Default battry life
HI,
What is the average life span of a battry? I have a 09 FXDL.
Thanks
Old Feb 15, 2012 | 12:50 AM
Bobby9621's Avatar
Bobby9621
Many factors, including cold, heat, vibration, storage, and if you use a battery tender. If you don't take care of it it could be 3 years to 5 years. If you take care of it and garage it you could get up to about 7. Batteries are being made better these days, as long as they have acid they should keep. But if it was poorly made, you get a short in the battery where the negative wire touches the positive plate which drains your battery. No way to correct the issue, it is in the manufactoring.
Old Feb 15, 2012 | 02:01 AM
bundy bruiser's Avatar
bundy bruiser
got 5 winters out of mine with the Dyna
I bought another HD one to replace it when it died
Old Feb 15, 2012 | 02:09 AM
Bobby9621's Avatar
Bobby9621
Expensive battery! Can't blame ya though...
Old Feb 15, 2012 | 02:58 AM
markkoby's Avatar
markkoby
Asking because I had a systems relay problem and when starting it would only give about five good cranks and that was it. Wondering if it should crank more or the motor is so big it drains battery quick.
Thanks for reply
Old Feb 15, 2012 | 03:01 AM
Bobby9621's Avatar
Bobby9621
Factory battery, factory engine, no major electric mods to suck it dry before the alternator can keep charging? Most likely just a battery dying before it's time. Disconnect the battery, hook up a volt meter, if it drops a few at a time at a steady pace, you have a short in the battery, it is toast.
Old Feb 15, 2012 | 05:55 AM
PigInaBlanket's Avatar
PigInaBlanket
I have had to replace my battery in my 07 Street Bob twice now. The first one got ruined about a year after I bought it, the negative cable kept vibrating loose and burned up the HD battery post.
Just replaced the second HD battery one I bought a little over 3 years ago. That one would lose it's charge when it sat a week to where it wouldn't even start the bike.
I bought a charger/tender about a year ago but don't use it as much as I probably should since I have to run an extension chord out to the garage. I'll try and use it more on this new battery and see if it helps the longevity.
Old Feb 15, 2012 | 06:57 AM
Good_Apollo's Avatar
Good_Apollo
I don't know if mine is the original or not, I'm thinking of replacing it this year just to be safe. I haven't had any issues and I leave it on the tender, but if the battery is now 12 years old, time for a new one!
Old Feb 15, 2012 | 07:04 AM
jeffreydsilver's Avatar
jeffreydsilver
Default If You're Asking - It's Time
2009 - If you're asking it's probably time! Lots of threads on here lately on batteries.
Old Feb 15, 2012 | 09:59 AM
revitonup's Avatar
revitonup
I've got an 06 Street Bob with the original battery in it, prior to this year it had always had a battery tender on it during the winter. During the last move, the tender turned up AWOL. Haven't had any issues with it.
