SuperGlide width
Old Feb 18, 2012 | 08:10 AM
AladinSane's Avatar
AladinSane
Default SuperGlide width
I am looking to get a 2012 SuperGlide. I have a storage issue. I am going to have to have to ride it up a ramp to park it in my back room and am not sure if it will fit through a 36" door. How wide is the widest part of the SuperGlide?
Old Feb 18, 2012 | 08:22 AM
PoCoBob's Avatar
PoCoBob
I don't know how wide the "bike" is but it will definitely go through a 36" door. The problem will be the bars and mostly the mirrors. Depending on your ramp, if you can stop and put your feet down you should be able to get any width bars through the doors by leaning it left then right to wiggle through. If it's a ramp that you can't stop once you're on it you may have to change the bars and mirrors.
Old Feb 18, 2012 | 10:05 AM
JohnC FXDX's Avatar
JohnC FXDX
It would be the bars. Probably around 30-31" at the most.
Old Feb 18, 2012 | 10:21 AM
ynots's Avatar
ynots
2012 Harley-Davidson FXDC Dyna Super Glide Custom - USA Specifications/Technical Details
Dimensions
Length 92.9 in. (2360 mm)
Overall Width 38.9 in. (988 mm)
Overall Height 48.5 in. (1232 mm)
Seat Height:
- Laden2 26.3 in. (668 mm)
- Unladen 26.5 in. (673 mm)
Ground Clearance 4.6 in. (117 mm)
Rake (steering head) 29°
Fork Angle 29°
Trail 4.7 in. (119 mm)
Wheelbase 64.2 in. (1631 mm)
Old Feb 18, 2012 | 11:19 AM
Bobby9621's Avatar
Bobby9621
Just do the lean method as mentioned above, I don't know about doing that every day, but for my bike, worth it!
Old Feb 19, 2012 | 03:17 PM
AladinSane's Avatar
AladinSane
Thank you all for the assist.
I just put a deposit down on a Street Bob. I have a few weeks to get my new shed built so I should be good.
Damn.....my first HD is on it's way!!!!!!!!
Old Feb 19, 2012 | 04:34 PM
voneville's Avatar
voneville
Put a set of T Bars or drag bars and risers on it. You can loose a lot of width that way. I think my bike is 28 inches wide now.
PRrdglide
11
Mar 4, 2018 09:19 AM
CaptainKirk
2014-2024 Touring Models
15
Jun 23, 2015 05:55 AM
cas0905
Jan 9, 2015 08:25 AM
1HDRIO
Jun 11, 2014 09:49 PM
Dyna346
Jul 15, 2012 08:07 PM
