2012 FXDWG/FXDC ignition switch
Old Mar 16, 2012 | 12:13 PM
fonso003's Avatar
fonso003
Originally Posted by blueangel73
I want to see where this thread is going!
Well since the electrical system is new for 2012 on the dynas we cant use that 3 prong ignition switch that is in all the
ignition relocation threads on the forum.
I wanted to see what that plug looked like on the new wide glides to see if that switch can be used on the 2012 SB.
I have confirmed that the plug is identical to what I have on my neck ignition.
I am going to do this mod when I get back to the country in two weeks.
To help all the guys that have the '12 SB and want the mod. Me being one of them.
The ignitions switch removal ant mounting on the dash will all be the same, but from when I remember taking the
ignition of my bike I believe there is enough wire to just feed through the neck hole to plug directly to this switch.
Old Mar 16, 2012 | 12:30 PM
blueangel73's Avatar
blueangel73
Gotcha! I totally understand the issue, I went through this about a year ago when I wanted to switch my ignition and coil over to the granade still used on the Softail Rocker models. They also only use a two wire system and I was trying to figure out how to rewire the three wire system into the two wire system. I didn't give up the idea, I just didn't want to invest in a Softail service manual just to have the wiring schematic.
On another note, I wonder if the new wiring setup on the new Dyna's will work with the granade ignition and coil?
Old Mar 17, 2012 | 02:05 AM
fonso003's Avatar
fonso003
Im pretty sure that it will. As a matter of fact I noticed that the '11 softail ignition switch and the "12 wideglide switch are the same part number. So I'm assuming that the plug on the grenade is the same.
Old Mar 17, 2012 | 08:20 AM
blueangel73
Now if I can figure out how to convert my three wire system into the current two wire system so I can use the grenade coil and ignition switch.
Old Mar 17, 2012 | 08:30 PM
Stag556's Avatar
Stag556
This is an awesome mod. I'll definitely be doing this in the future. Now if only I could find the ignition switch in gloss black....
Old Mar 19, 2012 | 07:54 AM
blueangel73
Can any of you with the newer two wire systems provide a wiring diagram of this new set up?
Old Apr 16, 2012 | 11:32 PM
fonso003's Avatar
fonso003
So far I really don't understand how the signal is sent and received from the existing switch. The issue is that neither of the 2 wires are a 12 volt wire they are more like data cables.
Old May 4, 2012 | 08:31 AM
cl605nick's Avatar
cl605nick
Fonso,
Ive been reading a little re the CAN bus and get the impression that the wiring mearly sends signals to the modules to instuct them that an input is required etc. I have changed the indicators on my 2012 SB to LED's and didnt need any load equalizers etc as the CAN bus takes care of all the voltage drop scenarios etc. Its really very clever! I have heard though that if you find any wires that are wrapped around each other LEAVE THEM ALONE! This is CAN bus wiring and will cause you serious Headache/Heartache/Bank Balance Ache etc if messed about with
Im really wanting to do this switch mod to my bike too. How are things going with yours? Any updates/progress?
Cheers
Old May 4, 2012 | 08:59 PM
fonso003's Avatar
fonso003
Originally Posted by cl605nick
Fonso,
Cheers
Thats exactly correct. The two wires are just a send and receive wire. The most current it sends ever is about 3 volts. Any module on the bike that is linked in to the hdlan system has a micro processor that sends an on or off signal, plus a diagnostic signal. From what I read it is all numeric. I havent ordered the switch from harley yet. I posted a couple of part numbers earlier in this thread, those are the only ones of that style that will work. (unless you are handy with coding micro chips). The part numbers are in the write up on the forum for the mod: HERE
Im not sure if you have had your ignition switch out of the neck yet, but the plugs from the pics that wisewoody was awesome enough to post for us, are the same as what is in our bikes now.
I am still doing this mod but since the switch is about $150 Ive been putting it off. I'll post progress though, Im glad this is helping others
Old May 5, 2012 | 03:42 AM
cl605nick's Avatar
cl605nick
Thanks for that,
Its good to know that the plug should just snap straight in and will make life alot easier. This is def something I will be doing, the original location of the ign switch is such a pain compared to my old FatBoy, but may leave it until winter time. Having said that, the weather here in the UK is still like winter........ lol
