Switch Caps
Old Feb 20, 2012 | 08:51 AM
Govno's Avatar
Govno
Default Switch Caps
I was thinking of replacing my black plastic switch caps to the chrome ones.
I see they sell a Chrome Switch Cap Kit, Part #71804-03.
Are they easy to replace? Do I need to take the handlebar assy apart or do the old caps just pop off and the new ones pop on?
Thanks for the help!
Old Feb 20, 2012 | 09:02 AM
rh8234's Avatar
rh8234
The Chrome ones are plastic too. Chrome plated plastic. You will need to take the switch assemblies off. The switch caps do NOT pop off. You need to get at them from the inside. It is not a difficult job at all, but you will be dealing with tiny springs and working in a small space. Just be careful putting the switch housings back on - do not pinch any wires between the housings and the handle bars. If you do, your next post will be "why do I keep blowing fuses".
Old Feb 20, 2012 | 09:06 AM
Baeseman1's Avatar
Baeseman1
To answer all of your questions - kind of...
Easy? Kind of. The first time, it's not a 5 minute operation like it looks like. But once you're done, you'll say it was pretty easy.
Handle bar assy apart? Kind of. There's only a few screws holding the switch housings together and that's all you need to take apart.
Pop off/pop on? Kind of. Because they are plastic, you need to go easy on install so you don't break the little tabs. But it takes a decent amount of pressure to snap them on.
Old Feb 20, 2012 | 09:54 AM
bigdaddy33's Avatar
bigdaddy33
The prior owner of the 2010 RG I bought switched to the chrome switch caps (and the chrome housing). I guess I'm getting used to it, but I think I prefer the look of the black caps, especially with the chrome housing. Post up some pics when you finish the job.
Old Feb 20, 2012 | 11:01 AM
Tundra bob's Avatar
Tundra bob
It's quite easy to do. Just undo the few screws holding the housing together. There should be one small screw holding the switches in place if they are not held in with pressure. The new caps just snap down over the existing caps. Takes a bit of pressure and placement, but after the first couple, the rest get easier.
Old Feb 20, 2012 | 11:15 AM
RDK09's Avatar
RDK09
IMO they were a pita but i did em in the cold. My advice, heat up the chrome switchcaps with a heat gun or blow dryer before trying to install them, makes em abit more pliable, learned this the hard way after breaking my starter switch cover. Also be careful not to break the tiny nub off of the front brake switch when putting everything back together, if the front brake lever won't give after its all back together DON'T force it as it will snap said nub.
Old Feb 20, 2012 | 11:53 AM
rh8234's Avatar
rh8234
el-wrongo - the new caps do NOT snap down over the existing caps! The black caps must come out and the new chrome ones are a replacement for the originals!!! These are NOT crome covers that go on top of the existing switches. The chrome ones are replacements for the stock black ones. Still - not a difficult job to do at all though.
Old Feb 20, 2012 | 12:19 PM
Robtarra39's Avatar
Robtarra39
I put the new chrome caps in HOT water to help them bend a little before installing.
Old Feb 20, 2012 | 01:26 PM
KevenW's Avatar
KevenW
I had HELL getting my chrome caps on. The plastic is much harder than the black ones. The tabs are thicker too. I broke one tab. Use vaseline or something on the tabs. A jewelers flathead screw driver helps. Make sure you align then correctly or you'll be redoing them. They have little splines on them.
Old Feb 20, 2012 | 03:50 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Here's a link to the Instruction Sheets from my database.
Read these instructions thoroughly, take your time, do it step by step and you'll be OK
Originally Posted by FXD2003Rider
New addition to the database:
71804-03 ... chrome switch cap kit
FXD2003Rider
