Going from Spokes to Mags ... Brakes ?
Old Feb 24, 2012 | 11:40 PM
por2gezo's Avatar
por2gezo
Default Going from Spokes to Mags ... Brakes ?
Hey guys,
I was looking up some brake pads for my 06 Dyna FXDBi and noticed that on one site ... EBC that the brake pades were for Spoke wheels ... why would this be ... arent brake pads, brake pads ??? regardless of what wheels you have ?
Also, while I am on the topic. what do you all recommend for brake pads ? I only have to change out the rear pads, this time around ... any suggestions ???
and as for the fronts ... do any of you have a rattling that comes from from your front wheel when braking ??? what is it ?
Old Feb 25, 2012 | 07:09 AM
8541hog's Avatar
8541hog
Not really a rattling, more like a buzz when I brake, have the Lyndall Gold Plus pads and have had the noise since installing them, has to do with the holes in the rotors I believe.
Old Feb 25, 2012 | 09:41 AM
JohnC FXDX's Avatar
JohnC FXDX
Don't the laced wheels have a traditional style rotor and the mags have a big ring on certain years? If that is the case with your year, then that us the difference.
Old Feb 25, 2012 | 02:19 PM
back again's Avatar
back again
You need to make sure the pads are compatible with the rotors.Lots of choices now with different pad materials.Wrong match up will cause what your describing.
Old Feb 25, 2012 | 02:25 PM
ynots's Avatar
ynots
Mine don't rattle but every since the bike was new I've had a slight buzz while braking. I'm sure its the holes in the rotors
Robbie13's Avatar
Robbie13
LOSER
I had to have the rotor to fit the mags when I changed from spokes. I kept my same pads though, no problems.
Old Feb 25, 2012 | 08:58 PM
por2gezo's Avatar
por2gezo
So you are saying that me and the guy trading also need to trade rotors ? both him and have have 2006 Dyna's and was hoping that all we had to do was trade wheels ??? am I wrong ? what else is involved ?
Old Feb 25, 2012 | 09:10 PM
Robtarra39's Avatar
Robtarra39
my bike is an 02, i had the stock mag wheels and purchased a 21 spoke for the front and i reused my rotor with no issues at all, the same for my rear wheel when i did the change to spoke.
Old Feb 26, 2012 | 10:25 AM
16VAFXDL's Avatar
16VAFXDL
When I swapped from spokes to mags on my 08 FXDC, I had to get a different front rotor. Has to do with the difference the in the way the center of the wheel is made on a mag. The front rotor was more like a ring than the big disk that is standard. I did not have to change the rear rotor with the mags. I just installed the standard Harley brake pads just like were on the bike before when I had to change my pads last fall and I have not had any problems.
Old Feb 26, 2012 | 10:27 AM
8541hog's Avatar
8541hog
Not all mags are the same, it depends on which ones you get. Mine use the same as the original spokers I had.
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
