PC III Throttle Setting
Old Dec 19, 2006 | 12:53 PM
Babe's Avatar
Babe
Default PC III Throttle Setting
Can the 0 & 100% throttle positions be calibrated on a PCIII USB without starting the engine, and, if so, how?
Old Dec 19, 2006 | 02:26 PM
mikeurig's Avatar
mikeurig
Default RE: PC III Throttle Setting
I was told by FuelMoto "NO". That the engine had to be running but I also heard that you can use the battery for power.
Old Dec 19, 2006 | 02:44 PM
thrillseeker's Avatar
thrillseeker
when you purchased the pciii, you should have gotten a little 9 volt battery adapter thingy. Thats how you connect the pciii to a computer if you cant do it at the bike. If you don't have the thingy, you will need to contact powercommander and get one from them (unless someone here has a spare they will send you)
Old Dec 19, 2006 | 02:47 PM
Zyklon's Avatar
Zyklon
Power Commanders web site tutorial states that the engine should be running and warmed up to a normal idle speed when you set the throttle position. As far as setting the throttle position when the PCIII is not connected the bike, I do not see how that is possible.
Zyklon
Old Dec 19, 2006 | 05:32 PM
Shrug's Avatar
Shrug
I believe you can set it with the battery adapter if the motor isn't running. I did mine with the motor running. There's a rev limiterso you're not going to overrev the motor. Only takes a few seconds to do and you'll know it's right.
jackinthebox
Apr 18, 2011 09:47 PM
AFblacksheep
Jan 26, 2010 12:23 PM
creekhed1
Aug 1, 2008 02:59 PM
SC-Longhair
Jul 4, 2008 05:42 PM
JoeSwiatek
May 16, 2008 12:54 PM
