Internal wiring
Old Dec 20, 2006 | 01:36 AM
The Dude's Avatar
The Dude
Default Internal wiring
I am thinking about drilling my stock stainless bars ,2001 wdg,and running internal wiring but am now wondering if I should, after reading about the late model bars being recalled for cracks in the wire entrances. Any body run into any troubles with this mod or have any other insight into this?
Old Dec 20, 2006 | 03:40 AM
TOMMAY's Avatar
TOMMAY
Default RE: Internal wiring
My thinking on this is that your riser clamps will be on each side of the hole you'll drill for the wires providing support if the bar does crack which I don;t think will happen.Drill the holes and deburr with a dremel tool or some such and I wouldn't think there would be a problem. People do it all the time.
Good Luck
Tom
Old Dec 20, 2006 | 11:34 AM
Hey Joe's Avatar
Hey Joe
Old Dec 20, 2006 | 02:13 PM
phreak's Avatar
phreak
I bought a set of aftermarket bars, 1", and drilled them phor internal wiring. They've been on phor close to a year now, and no issues with cracking.
Like Tommay said previous, just make sure you debur it throughly, and don't make too big of a hole.
Old Dec 20, 2006 | 07:47 PM
badherb's Avatar
badherb
I was thinking that I would do the same thing on my 97fxdwg. the stock bars have small holes for the zip ties to attatch to the bars. I was goin to drill them out and debur. feed the wires through. seems to be enough slak in the harness to do it with out too much trouble. when the weather gets warmer I'll get her out and let you know how it goes.
Old Dec 20, 2006 | 08:45 PM
Naz_Man's Avatar
Naz_Man
I drilled stock wide glide bars and haven't problem at all..... be prepare to pull your hair out getting the job done Just take your time and you'll get r done!
F86
Jan 10, 2018 02:34 PM
Griff012FLHX
Dec 27, 2016 09:32 PM
3skulls
Jan 25, 2011 10:29 AM
drogers
Jun 1, 2008 06:26 AM
HDF Tech
Jun 25, 2005 06:46 PM
