Internal wiring for bars
Old Jan 24, 2011 | 04:21 PM
3skulls's Avatar
3skulls
Default Internal wiring for bars
I'm looking at getting the bitwell tracker bars and wanted to go ahead and do the internal wiring.
How hard is this to do? Do you have to cut the wires? Do you get the bars without dimples if you go internal?
Thanks in advance.
Old Jan 24, 2011 | 04:38 PM
grancuda's Avatar
grancuda
You don't have to cut the wires, just diassemble the connectors using a paper clip. Don't buy dimpled ones, just get the standard ones.
All the tools you need
Connector ends after you diassemble
Ran mine through the center the first time, my bars now I did 2 separate holes
Don't forget to make note of your wiring colors!
Old Jan 24, 2011 | 04:41 PM
papadop88's Avatar
papadop88
like grancuda said, get the standard ones, punch three holes in it and wire em...post pics when your done too, or it never happened.
Old Jan 24, 2011 | 04:44 PM
3skulls's Avatar
3skulls
Ok cool. I didn't know the wires will come off the connecters that easy.
Thank you sir.
Old Jan 24, 2011 | 04:48 PM
3skulls's Avatar
3skulls
Damn thanks for the pics too.
Pics will be posted.
I'm trying to knock out a few things while the roads are frozen.
Old Jan 24, 2011 | 09:53 PM
Gbav1's Avatar
Gbav1
you got to work at it a little bit to get the connectors apart, but it's better than cutting the wires. Just make sure you debur all the holes so you don't chaff you wires down the road. I milled a slot in mines to give it a little wiggle room. I also moved my turn signals to the down tubes, which made for less wires in the handlebar.
Take your time!!!!!!!
Old Jan 24, 2011 | 10:15 PM
daltrey's Avatar
daltrey
You can get a close up and see how the Deutsch connectors come apart here. http://linson.us/harleydavidson/spor...ter_instal.htm I've ran the wires inside my stock bars and you're gonna spend a few hours doing it. Make sure to make a drawing and label what color wires go where before you take em all out of the connector. I just wrote it down in my service manual. I think there were 8 wires per side. I wiped em down with baby powder and tied kite string to em and used a shopvac to pull the kite string through the handlebars and then just pulled em thru.
Old Jan 24, 2011 | 11:10 PM
jesse-austin's Avatar
jesse-austin
Default sure about non-dimpled bars?
You sure dimpled bars aren't required?
I bought a set of drag bars that weren't, and the wires exiting the hand controls were pinched because of the location of the exit holes in the respective housings, and as a result, they wouldn't mount right without the recess in the bars. I wired another bike of mine internally, and the holes in the bars for the wire were at the end of the dimple so the wires were effectively hidden.
Old Jan 25, 2011 | 08:24 AM
onebagger15's Avatar
onebagger15
You don't need dimpled bars.
You are going to spend a few hours doing wiring. Once you get the hang of it, it's not too bad. A bit of finese is required.
I tied fishing line to a bolt nut to thread, then re-tied the bolt nut to some clothes line string and pulled my wires that way. I have z bars so this should be a bit easier for you.
Good luck.
Old Jan 25, 2011 | 08:46 AM
grancuda's Avatar
grancuda
With tracker style bars there is no need for attacing any line or string, you jet shove the wires through one at a time and when you see them through the center hole just grab them with some long skinny needle nose or bend a little hook on a paperclip and pull them out the hole. I bet Z bars and stuff would be a pain.
