Soft Front Brake Lever
Old Mar 9, 2012 | 04:08 PM
JerryDinMD's Avatar
JerryDinMD
Default Soft Front Brake Lever
ok-changed handgrips-had to change the sleeve which meant take all that crap off-got everything back on-but now my brake lever is soft-i had an issue not long after i bought the bike with a soft feel-took it back and fixed the problem-didn't tell me what exactly-just said it was "re-adjusted"-any help id appreciate it--thanks
'11 superglide
Old Mar 9, 2012 | 04:16 PM
JRK5892's Avatar
JRK5892
just bleed out the front brake bud you should be fine
Old Mar 9, 2012 | 04:24 PM
JerryDinMD's Avatar
JerryDinMD
yea but it was ok before-and no air should be in the system-i really dont want to go that way if i dont need to
Old Mar 9, 2012 | 04:49 PM
rdondes's Avatar
rdondes
JRK is correct. Bleed the front brake. Or have your shop do it for you. It doesn't matter which "way you want to go" - if you have a soft front brake, it needs to be bled before you have an accident.
Old Mar 9, 2012 | 04:52 PM
JRK5892's Avatar
JRK5892
just moving things around can cause air to get in there did you move the master around? that can do it... bleeding takes about 5 min and is super easy. just bleed it... pop a line on the caliper, into a small amount of brake fluid, pump the brake and crack the bleeder, be sure the master stays full, pump it a few times, tighten, pump it again, crack it and close it up... done! take 5 min and worth it when it comes to brakes
Old Mar 10, 2012 | 03:05 AM
JerryDinMD's Avatar
JerryDinMD
ok thanks alot guys-i did move the master cylinder and everything on the right side around-was putting on new mirrors and grips-i'll bleed them out--thanks again
Old Mar 10, 2012 | 04:16 AM
Foxster's Avatar
Foxster
Old biker tip: You can often get it to firm up just by tying the lever back overnight.
Old Mar 10, 2012 | 09:12 AM
MX888's Avatar
MX888
I know it's a 2011.. but brake fluid can and will get moister in it.. the shop may have put in some that has been open for some time or just old, over heating could have the same effect. I myself would change it all out with new. Not very hard to do. Coming from motocross I did this all the time since front breaking is huge in that sport. (break fade) then would be spongy after. Hope this helps.
RandyDowdy
Feb 26, 2019 08:27 AM
PaulWall725
Apr 20, 2010 04:48 PM
Steeler
Feb 23, 2010 04:43 AM
fxstbharley2008
Softail Parts
Sep 20, 2009 05:43 PM
deeblues
May 18, 2008 03:48 PM
