Need advice...I was attempting to install my removable saddle bags on my Street Bob. One of the brackets is mounted behind the rear shock. So I took the shock off and now I cant figure out how to get it compressed enough to get it back on. The bike is on the ground. I dont have a jack. Probably would have solved my issue. Any suggestions on how to get the shock back on? Do I need to get a spring compressor?
Get the back wheel off the ground with either a hydraulic car jack, or just a screw jack , then remove both shocks and install the new ones. If you only want to get the original back on then the back wheel still has to come off the ground. You could achieve this with the help of a friend. As you lift the bike the pressure should even out.
Thanks guys. I will figure out a way to jack it up. i do have a floor jack but it wouldnt fit under the bike. I saw someone mention roll the bike up on a block of wood then jack it up. I might try it. Im nervous of the bike falling tho.
