Switchback wheels on a 2010 Superglide Custom
Old Mar 24, 2012 | 11:53 AM
Rainmakr's Avatar
Rainmakr
Default Switchback wheels on a 2010 Superglide Custom
Anybody know if the stock switchback wheels will fit a 2010 superglide custom with only slight modifications?
Old Mar 24, 2012 | 02:16 PM
wyldspirit's Avatar
wyldspirit
Originally Posted by Rainmakr
Anybody know if the stock switchback wheels will fit a 2010 supergllide custom with only slight modifications?
You can get the rear to work on your bike but the front being an 18" might pose a problem. From what I have seen in the parts catalog you would have to get the Bearing assembly for it but you might want to check the clearance from the fender to your stock wheel you have currently. Bob or Tim might be better to answer this though
Old Mar 24, 2012 | 04:01 PM
Rainmakr's Avatar
Rainmakr
Thanks wyldspirit. I saw from the HD website that the rear would work. They are the same size so it should be a direct swap. The stock on the 2010 fxdc front is a 19inch. I was hoping that it would be another direct swap but not sure.
Old Mar 24, 2012 | 04:10 PM
crimson13's Avatar
crimson13
I was planning on doing this same thing to my street bob, I was told that front end was different 41mm and that the 130 tire on the front would not fit with out modification
Old Mar 24, 2012 | 06:03 PM
Rainmakr's Avatar
Rainmakr
Thanks for the info crimson13. Im sure that there are some similar aftermarket ones that will work. The search continues!
Old Jan 2, 2014 | 06:43 PM
machm1969's Avatar
machm1969
There's a guy on harley-davidsonforums.com that put them on an '06 Superglide. He used WG forks with V-rod lowers I believe. I'm planning on doing this on my '07 WG soon.
Matt
Old Jan 2, 2014 | 08:25 PM
Sticky4's Avatar
Sticky4
I have a set of Switchback wheels for sale.
https://www.hdforums.com/forum/dyna-...ld-wheels.html
Old Jan 4, 2014 | 03:11 AM
Jondalar's Avatar
Jondalar
Here's mine. If someone finds a 19in front that looks like a switchback wheel let us all know.
DragonSlayer53
Harley-Davidson Street
Jul 17, 2019 02:16 AM
Hurricane19
Mar 19, 2015 04:07 PM
stbobshadow
Nov 23, 2011 06:00 AM
Robbie13
Dyna Parts
23
Feb 1, 2011 09:06 AM
Big Tom
Oct 16, 2009 12:58 PM
