Yellow stain on outer primary (possible gas leak)
Old Apr 3, 2012 | 10:58 PM
DynaSG07's Avatar
DynaSG07
4th Gear
Default Yellow stain on outer primary (possible gas leak)
Had a yellow stain on my outer primary cover from it sitting for a month while i was training in the field. The wife started the bike about once a week let it run and that was it it was not moved. The stain is directly under were the quick disconnect is for the gas tank. I had this "o ring" replaced. Just wondering if anyone would know what this could be. Thanks. I"ll post pictures if you need it.
Thanks all for your help.
Old Apr 3, 2012 | 11:09 PM
ynots's Avatar
ynots
letting the boyfriend ride the bike? j/k
Id say the o ring is leaking. might try some goof off and a tooth brush
Old Apr 3, 2012 | 11:12 PM
DTDK's Avatar
DTDK
solvent and a tooth brush will help, if the goof off does not work i would try acetone, as it should just be alumnium, or some metal polish
Old Apr 3, 2012 | 11:38 PM
DynaSG07's Avatar
DynaSG07
4th Gear
Yeah i used purple power it came off. Am i going to have to get it replaced again was all or is this a normal problem for these bikes. and thanks for the cleaning tips i'll file those in my book of things to clean lol
Old Apr 3, 2012 | 11:49 PM
DTDK's Avatar
DTDK
mine leaked one when the line was not plugged into it, but i think that was a freak thing, other then that i have not noticed and drip marks
fxrjohn
Dec 30, 2010 08:01 PM
MGN54
Jul 19, 2010 03:49 PM
chop66
EVO
31
Jul 14, 2010 03:54 AM
52edub
Sep 6, 2007 09:43 AM
Canuck HD
Jun 13, 2007 07:35 PM
