Those with 100+ TQ and HP
My build is similar to Joe's (JRK5892) above:
H-D Screamin Eagle big bore cylinders
H-D Screamin Eagle flat top cast pistons
H-D Screamin Eagle MCR (Manual Compression Release) heads
H-D Screamin Eagle 1.725 rocker arms (intake side only)
H-D Screamin Eagle perfect fit pushrods
Andrews TW37B cams
Paughco 2-into-1 exhaust
Goodson air cleaner
Sifton A/C mount and breather system
I converted my stock closed loop electronic fuel injection to open loop using the ThunderMax with AutoTune EFI / ECM module ... totally replaces your stock ECM ...
I had the exhaust modified by a muffler shop to adapt it to fit my Super Glide ... it is P/N 733C9 designed for Touring models ...
SOTP indicates this build is putting out upwards of 95 HP/TQ ... I've been really pleased with the build ...
R/
'Chop
2008 FXDF Dyna Fat Bob
96"
Big Boyz Heads
0.030” head gasket 190/190ccc
Andrews TW37 advanced 4* (34* IVC)
SE High Ratio Rockers 1.725” (.541” lift)
Thunder Max w/Auto Tune
V&H Pro Pipe
K&N Filter
30T pulley
Barnett Spring Conversion kit w/6 coil springs
My 2010 Street Glide build is reflected in my sig line and has been very reliable. I have well over two years on the combo and pleased with it as a stable touring platform.
My 2006 Street Bob has an SE 120R in it. When considering a build, the SE 120R seemed to maximize the bang for the buck as it were. The only adds I included in the build were roller rockers, Latus / Baisley throttle body and manifold, VH pro pipe hi output. This bike is tuned with SERT and has been a strong reliable performer. It has one year on it and I wouldn't hesitate to go out of town on the bike. I call it my 200 mile bike (100 miles each way from the house) simply because I have a bagger which is more comfortable for longer trips. The street bob also has a solo seat and occasionally the wife thinks she should tag along...
