Gold Rims and Chrome Front End on my Low Rider
I think in my last thread I mentioned that I unsuccessfully tried to swap my wire laced rims with a guy's 13 spoke mags from his 2003 FXDL. After realizing a 1" sleeve won't fit in a 3/4" hole (surprise, surprise) I put his bike together and figured I'd powdercoat my rims as they were already off the bike.
While things were apart I added chrome fork sliders and stuffed those with a Race Tech Gold Emulator kit and Race Tech springs. I lowered the front 1" to level out the factory stance of the Low Rider. We'll see how it handles after I bleed the brakes and set the steering head bearings.
Here's a few comical things I learned along the way:
* If a sprocket bolt is going in crooked and takes a 2 foot 1/2" drive breaker bar to tighten, don't keep tightening it. No matter how much you hope, it won't straighten itself out. I got to practice my Heli-Coil skills today.
* Before drifting a new Timken bearing onto your steering stem, packing top and bottom bearing with grease and installing your trees and handlebars - put the $1.99 dust ring on the steering stem.
* If you value your sanity and are able to swallow some pride, pay someone to lace and true your wheels.
Thinking if I were to do it over, I might have gone with a gloss clear coat on the rims versus the flat, but I do like the flat contrasting with the chrome.
Thanks for looking.
Rock on
It doesn't take very long to get good at lacing wheels. By my 3rd wheel, I believe I was down to 9 minutes. If you have your own Truing stand (Harbor Freight $39, Dial Indicator $49), you can true your wheels with the tires mounted for the ultimate precision. The factory spec. is within .030" and mine (with tires mounted) are well under .010". You can also use the stand to balance your wheels yourself. Nobody cares as much as the rider about straight and balanced wheels. Mine feels just as good as the cast wheels on my Electra-Glide.
As for the truing, I used to be pretty good with dirt bike rims, but it'd been about 3 years since I'd touched one; gotta stay in practice! I felt like I was all thumbs.
