PCIII EFI rant
Old Dec 30, 2006 | 10:23 PM
Psycho's Avatar
Psycho
Default RE: PCIII EFI rant
After the trouble of getting the thing out and setting up for those shots in the dark, I sure hope the pictures help.
I'd like to note that I wrap the PCIII up in a shop rag to protect it before I stuff it in the hole. I just uncovered it so you could see what is going on in the pictures.
Hope you can make some sense of where the connectors are.
About 7500 miles on this setup with no troubles.
Goood luck.
Old Dec 30, 2006 | 10:35 PM
darkdyna06's Avatar
darkdyna06
My front 02 sensor was also cross threaded, The bung peeled right off the pipe when I went to take it out. I was able tosplit the bung with a cut off wheel without ruining the sensor, but I'm not sure if it will ever come out of the new pipe. what were they thinking?
Old Dec 30, 2006 | 10:55 PM
haksaw's Avatar
haksaw
Thanks Psycho. Like they say, a picture is worth 1000 words. Apparently drinking more wasn't working but those pictures will help. I appreciate the sympathy.... i took the battery out so that should make things easier tying things down.
thanks again
haksaw
Old Dec 30, 2006 | 11:49 PM
haksaw's Avatar
haksaw
done deal... i mounted it the same as psycho. I don't know if some pciii come with shorter harnesses or not but it sure seems to be quite the strain on the wires mounting it where i did...in any case thanks again...i hope never to need the sympathy of the forum ever again. Now onto the easy/fun stuff...pipes.
Old Dec 31, 2006 | 12:06 AM
Shrug's Avatar
Shrug
ORIGINAL: haksaw
Glad you got it done! If pipes are next, PCIII mapping changes are on your radar screen. Did you leave the USB cable connected?
Old Dec 31, 2006 | 12:08 AM
Psycho's Avatar
Psycho
ORIGINAL: haksaw
Good deal. I hope yours works out as good as mine has.
Old Dec 31, 2006 | 01:27 AM
haksaw's Avatar
haksaw
i had fuel moto do the mapping on the pciii before they shipped it for the pipes i'm installing now so all should be good
Hawg295
Jul 4, 2008 01:10 PM
jrspringer06
15
Mar 11, 2008 03:49 PM
Rotorcycle
Jun 14, 2007 03:38 PM
kwas
Feb 14, 2007 08:05 AM
Sleeps In Trees
May 23, 2006 10:48 AM
