Twin Cam 88 Problem
Old Dec 15, 2012 | 11:52 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Originally Posted by kenna
...05 wide glide here,the fuel line "inside tank"...got a tiny pin hole and was sucking air due to engine vacuum suction...
Thanks for your input, kenna.
Won't help OP to solve his problems though. His '03 FXDL is carbed while yours has the fuel pump inside the tank.
Old Dec 15, 2012 | 12:30 PM
gdt3's Avatar
gdt3
Originally Posted by jbubbalee
Where can you get a manuel fuel valve? ----- Thanks, James
I got mine on Ebay. It was a pretty decent one for way less than a Pingle. I didn't want to pay for a Pingle as I was still trying to sort out my problem. Now that I have, I will probably put the stock vacuum operated fuel valve back on. If you search for fuel valves, you need to spell it manual.
Good luck.
skinman13
Feb 7, 2018 04:01 AM
triple604
Engine Mechanical Topics
Mar 5, 2017 06:35 AM
fastalkintn
May 30, 2011 03:03 PM
ACHALLIE
Shovelhead
Oct 16, 2007 11:18 AM
MAGSGLIDE
Exhaust System Topics
Apr 11, 2005 08:05 PM
