Handlebar change
Old Jan 2, 2007 | 02:32 AM
jmbear328's Avatar
jmbear328
Default RE: Handlebar change
Hope this helps,.......
John
Here is a parts list that I got from Zanottis for the CVO Dyna bar and gauge setup.
56973-07 CVO handlebar chrome $357.50
67880-94 Boot, reset switch $1.31
67925-04 Tapered mini tach Ga $13.88
67952-96 Gasket, Isolation, M $4.22
67956-96 Screw, Flat socket M $2.41
68953-04 Blackface mini tach $95.74
69853-07 Ring, Tach MTG $14.24
69854-07 Bracket, Speedo Mount $20.74
69855-07 Bracket, Ring, Indic $14.24
69868-07 Retainer, Indicator $2.54
71970-07 Wire Harness Instrument $166.00 at local dealer zanottis will be cheaper
46724-06 Diamondback brake cable $54.35
Total $747.17
I also used a chrome braided wiring housing cover purchased at autozone to cover all of the wires that I had to cut to give it a better look and I also bought a set of the H-D billet riser bolts and a set of chrome banjo bolts when I replaced the brake cable with chrome.
Old Jan 2, 2007 | 11:18 AM
gliderider's Avatar
gliderider
my07dyna,
I'd be interested in acquiring your take-off bars. Where are you located?
Old Jan 2, 2007 | 06:50 PM
04Lowrider's Avatar
04Lowrider
Stage IV
check out softtail standard handle bars. Worked great for me.
Old Jan 3, 2007 | 12:43 AM
jmbear328's Avatar
jmbear328
Ace777,
WOW,.... I sure wish I had known that before I bought my bars. Thanks for that very helpful insight.
John
Old Jan 3, 2007 | 04:08 AM
wwgilstrap's Avatar
wwgilstrap
I put risers on mine, no regrets..........
[IMG]local://upfiles/19227/CB244FE4E319459D85975149616F5A7C.jpg[/IMG]
Old Jan 3, 2007 | 12:03 PM
dav.elis's Avatar
dav.elis
What about your risers? 4 inch? HD? Have you modified your wires?
Thanks!!!
Old Jan 3, 2007 | 10:46 PM
wwgilstrap's Avatar
wwgilstrap
The pull back risersI used are from JP Cycle, part# 5000090. $59.99 I had to work the cables and wires around a little but didn't have to change them. I'm 5' 6" and doing this made the handle bars much more comfortable.
[IMG]local://upfiles/19227/5450227E2063483BB40AD9CB71497638.jpg[/IMG]
Old Jan 3, 2007 | 11:02 PM
DGlide04's Avatar
DGlide04
Take a look at the Wild Ones WO 560's, they're advertised as a pullback drag bar. I put a set on my '04 FXD and absolutely love the look of the T-bars and the extra pullback was a real bonus.
Just another recommendation.
Old Jan 7, 2007 | 07:41 PM
husky24tn's Avatar
husky24tn
i want to get rid of the mini apes i have...i'm not an "ape hanger" kinda guy....thats why iw anted to get mine off
i like the carolini look drag bar style....but everywhere i've looked i run into the problem of either the gauge mount or the light bar indicator reloaction is har to get done.
thanks alot for the part numbers and taking the time to share.....i'll get pics up when i get it done to mine
thanks again....your a lifesaver
Mitch
Old Jan 7, 2007 | 08:28 PM
jmbear328's Avatar
jmbear328
Well,.... be sure and add some pics when your finished.
John
Trial dog
Jun 12, 2014 04:49 PM
Grugrux34
Feb 28, 2012 04:29 PM
Capt416
Feb 18, 2011 03:44 PM
goatdriver
Aug 25, 2009 07:57 AM
