exhaust swap needs an ECM?!
Old Apr 25, 2012 | 08:03 AM
johnnybad82's Avatar
johnnybad82
Stage IV
Default exhaust swap needs an ECM?!
I recently got an 09 FXDB. Lover her but man she is pretty quiet with her stock pipes. So I've been looking at a set of Bassani Fireflight and have been reading that I should install a new ECM. Especially the Cobra Fi2000 PowrPro. My question is it essential that I upgrade to a new ECM to prevent suffering horse power loss and bad idles. I'd really like to swap those pipes, but the pipes, ECM, and air cleaner upgrade is running a 1700 dollar price tag. Just curious of yalls opinions. Thanks for the help guys.
Old Apr 25, 2012 | 09:04 AM
Stag556's Avatar
Stag556
No!!!! Lol. If you want to replace pipes, that's all you'll need. If you do an air cleaner as well, it would be a good idea to get a tuner. Your ECM is left alone.
Old Apr 25, 2012 | 12:08 PM
johnnybad82
Stage IV
Thanks Stag. Im new to all this new fang-dangled EFI stuff.
Old Apr 25, 2012 | 06:56 PM
trainedkilla's Avatar
trainedkilla
Just a power commander or a fuel pak if you replace the exhaust and air cleaner.
Old Apr 25, 2012 | 09:29 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Neither one. Install the A/C or pipes, one or the other, ride her around for 7-10 miles and let the factory ECM recalibrate itself. Then install the other mod, ride her around for 7-10 miles and let it recalibrate itself again. No need for what they're telling you to do.
Old Apr 26, 2012 | 06:06 AM
AFMM3's Avatar
AFMM3
That is all I did on both my bikes, and they both have run perfect for the last few years. Sure there is performance "left on the table" but that is not very important to me. I doubt either bike has ever seen 4k RPM, but they do see thousands of miles each year.
Old Apr 26, 2012 | 06:54 AM
11bDad's Avatar
11bDad
Not always the case. All bikes are different, and while what you are saying would apply to some, there are some where it just doesn't work. My 2010 FXDC ran fine with stock pipes & XIEDs. Added Rush slip on's and it then had a nasty decel pop. It took a tuner to eliminate the popping.
Old Apr 26, 2012 | 08:30 AM
johnnybad82
Stage IV
Wow man. Lots of different opinions here. Thats great. More info equals more tools to grab from. Ill get the pips on this months and let you guys know. I appreciate all the help. I come from a vintage brit bike background so I'm sure i'll have more questions as I go. Thanks again.
Old Apr 26, 2012 | 10:27 AM
ColdCase's Avatar
ColdCase
As many have said, swapping pipes and air cleaner doesn't hurt anything unless you routinely run it like you stole it. You will leave performance and drivability on the table, well even without pipe and intake changes you are leaving plenty of performance on the table. But if you are just ridding and want the sound or style, it is a don't care. The ECU has a base map that reflects the stock engine airflow. When you change pipes and air filter you change the airflow characteristics of the engine, especially above 3-4000 rpm. The ECU will adjust closed loop, perhaps it won't be happy but it will adjust. Open loop, when you ar on the throttle or during throttle transitions, the adjustments are not enough to compensate. They should be close enough for occasional hard riding, but I'd avoid running hard routinely. You need some kind of tuner to compensate.
I wouldn't bother with an air filter unless its for style. You won't see any performance difference without also tuning.
Every bike is a bit different, if you want to dial in the tune yourself, either to be sure its done right or you like to tinker, think about a TTS kit for your tool box. I have one and so does my neighbor and its probably the best tuning device for the back yard mechanic. Otherwise go to a competent tuning pro (not necessarily the dealer) for advice. Stay away from the add on boxes with canned maps unless you want to save $100 and are willing to live with the compromises.
atlantaallen
Apr 18, 2013 03:24 PM
deadhead948
Exhaust System Topics
Jun 2, 2011 02:24 PM
Supercell68
Nov 13, 2010 11:39 PM
moresky
Jul 14, 2008 01:14 PM
vinnypie
Dec 11, 2006 12:30 AM
