Help with horrible front end wobble
Old May 6, 2012 | 12:50 PM
SteveO-ll's Avatar
SteveO-ll
Some people have lowered there frond-end tubes by 3/8th's an inch in the trees, which has compensated the shorter rear shocks and the trail angle...........
So just a thought.
Old May 7, 2012 | 08:57 AM
lowriderrob's Avatar
lowriderrob
Whattsup,
Changing back to the longer stock shocks and having the problem go away, points to the fact that you are changing the steering geometery (the trail) by lowering the rear end of your bike.
Do yourself a favor do some research on "Motorcycle rake and trail".
There are a lot of good sites that explain how rake and trail effect the handeling of a motorcycle.
Old May 7, 2012 | 10:30 AM
Griff012FLHX's Avatar
Griff012FLHX
How your corner can have an effect also.
Keep adding power through out the corner.
And as said above, relax your grip.
Old May 8, 2012 | 04:29 AM
Tepidy's Avatar
Tepidy
Originally Posted by wattsupFXDC
Okay, I went back to stock shocks and went for a ride. It fixed the problem. I am wondering is it the progressive shocks being 11" compared to stock 12.6" or being the HD version causing the issue. Maybe a true-trak would fix it so I can go back to the more slammed look.
True track is for rear wheel wobble. By lowering your bike with the shorter shocks you changed the dynamics creating the front wheel to wobble.
Old May 14, 2012 | 08:53 PM
chino_1219's Avatar
chino_1219
Originally Posted by lowriderrob
Whattsup,
i agree. slammed the rear on my wg with 11" progressives and had a horrible wobble so i dropped the front an inch and the problem went away. running 16 in apes here and no problem doing 100 today with my buddy who just got his road glide. rake and trail is a common thing most people overlook.
Old May 14, 2012 | 10:46 PM
lo-rider's Avatar
lo-rider
I have a 2009 Dyna Glide Custom. I added 16 inch apes and slammed the rear with progressive 412 11" shocks. My scoot has a horrible front end wobble when I turn in sweeping turns above 60 mph. The bars will rock back and forth and almosted layed her down. I tried new drop in front forks, screamin eagle fork oil, adjusting neck bearing, fallaway... and nothing is fixing the problem. Has anyone had the same issue and remedied it? Is the rear shock change the issue?
"...modified the hell out of my bike and now it won't handle."
I have exactly the same bike: '09 FXDC Super Glide Custom, but all stock. By radically lowering only the rear, you have sufficiently imbalanced the steering geometry, destroying the handling. Lowering the front might help, but you will further reduce ground clearance and lean angles. If you must pursue this design you might wind up spending some dough trying various fixes and add-ons.
Gears of Joy
Jul 3, 2014 03:00 PM
rauchman
Mar 6, 2014 08:59 AM
baka1969
May 6, 2012 08:35 PM
JCleary
Jul 15, 2011 04:57 PM
grbrown
Jun 3, 2010 04:48 AM
