Seeking suspension "Guru" advice
The problem I'm experiencing is when riding a coarse paved road I'm getting a slight buzz (vibration) in the bars. For lack of a better term: Im getting more feedback from the road surface than I did with the slinky, dive bombing OEM springs.
I was wondering if trying some different fork oil could help eliminate those vibes. I replaced the oil (type E) on install and the forks have 1" of sag. Running 30 psi on stock scorcher, Dunlop K591 @ 40 psi back. Progressive 970 rear springs. I ride pretty aggressive.
I've heard varying reports on the weight of Type E. If its 10w would I be better going to a 5w or going the other direction to 15W?
I picked up the springs for cheap and eventually would like to change to a better setup. Anyone recommend a cartridge kit for 49mm tubes.
Tony
Eventually the Progressive's will go away. Just hoping maybe a fluid change could help
Lighter weight will result in a "softer" or sloppier ride depending on how your pushing it. Heavier weight, will be harder or more harsh.
I'm no expert on this, but suspension upgrades are my next mod instead of the engine as I was going to do, so been doing a lot of searching and reading on the subject.
It seems you have a few choices and your wallet is the only thing holding you back.
Do the Ricor drop in units with good single rate springs seems to be the best setup for the money.
The next step up would the full 30mm kits from Motorcycle metal to give the best tuning possible, but at many thousands of dollars of cash.
My plan is to buy the chassis stabilizers (have you done yours yet?) first, then my rear shocks then address the front end. I'll most likely end up with springs/intiminators with good oil in there for now on my front end.
The buzz or whatever your feeling is just more input which you will get with better suspension. You want to feel the rode, not isolate yourself from it. I'd also run a bit more pressure in your front tire.
Any suggestions on single rate springs to best accommodate the Intiminator?
I havent done stabilizers (TT) yet. I started with suspension mods and was impressed with the difference, it has helped minimize upsetting the rubber mount wobble but its definitely not a cure. Anyone with a rubber mounted engine who says their not having a problem must be riding like Mrs. Daisy.
When Im done with the front a true trac will be next.
Run more than 30 psi on front even riding solo?
From what I have read...race tech single rate springs seem to be good ones. Again, just what I have read and the direction I plan to go. Maybe call up Ricor and get their input on what to use with their product.
I run 38 pounds in my front tire and only solo ride. I believe max pressure is 40? Took some of the mushy feeling out of the front end, but now the mushy suspension rears its head.
FYI, I run a bit less in my rear...35-36 pounds.
I just put the Dunlop K591 on rear. I believe that's what your bike came with? Directional changes seem to be a little quicker. Its noticeably wider than Scorcher
I run a SE180 in the rear on mine, similar max pressure as the front.
