Air Cleaners......performance type.
Old May 26, 2012 | 06:25 AM
Gohot's Avatar
Gohot
6th Gear
Default Air Cleaners......performance type.
For those of you familiar with the S&S teardrop which is widely used because of the performance factor and simple good looks, there is a reason for the performance increase and it has to do with air flow. The S&S teardrop has a tapered cone on the inside which directs the air flow into the throat of the carb. Enough so that you feel an instant increase in acceleration. It is unmistakable the newfound power you gain. Owners will attest to what I'm saying.
Well, going the 'Sleeper' route, I wonder if there is a HD accessory air cleaner or insert that provides this same 'cone' ? or an accessory that can be used from an outside source? While the S&S air cleaner is a worthwhile addition, I was thinking like I say, in terms of 'stealth' or, stock appearance yet modified for performance. Anybody know if such a 'stockish' part exists? Old timers?
Old May 26, 2012 | 07:32 AM
Timmy B's Avatar
Timmy B
From: 12 year, Colombia, 4 years Mexico, currently In Kuwait, but Boston is HOME!!
I curently use a s&s dually onmy sporty and love it. Looks killer and I'm no expert or mechanic nor can I give you dyno numbers, but it flys.
Attached Thumbnails Air Cleaners......performance type.-good-l-sporty-dusty-at-and-at-rest.jpg
Old May 26, 2012 | 07:43 AM
Foxster's Avatar
Foxster
Umm, I have the S&S setup on my bike but I'm not sure that that spike inside the cover adds a huge amount. I'd say its more to do with the size of the air filter, the clearance around it and the raised venturi at the throttle body.
If I was to guess I'd say the spike does, as you say, help to direct the air and maybe it creates something like the Boyesen X Wing effect. So it might be worth looking into those type of gizmos. Having said that, they really don't ever show much, if anything, on the dyno.
Old May 26, 2012 | 01:40 PM
Gohot's Avatar
Gohot
6th Gear
It could be that lower performance motors do not feel the effect as much. I did it to a 98 Buell, ans with each mod I did, I could feel the increases.
HardLuck71
Nov 29, 2024 02:03 PM
Traxxtar
May 6, 2015 08:27 PM
17L1
Panhead
Jul 30, 2011 09:53 AM
snuffer
Apr 19, 2009 05:17 PM
edtexas
Jan 28, 2008 04:02 AM
