leak
Old May 26, 2012 | 06:39 PM
jojo2dog's Avatar
jojo2dog
Default leak
plug in side of primary leaking,the one that takes the place of the mid controls,when you change to fowards,anyone know of a quick fix or should i just go ahead and pull the cover.and if i pull the cover anything i should look for while i have it open
Old May 26, 2012 | 07:26 PM
SuperFastGlide's Avatar
SuperFastGlide
theres a little round gasket between the inner and outer primary where the shifter rod used to be...without the mid shifter in there running thru it, its prone to moving and causing leaks.... on mine i pulled the outer primary and sealed both halves from the inside with 2 freeze plugs from napa... if i remember correctly they were 9/16ths... but to be sure just take your outer primary cover with you when you go get the plugs...
Bob30247
Jun 6, 2025 10:30 AM
skidsareforkids
Aug 30, 2010 05:33 PM
SuperglideGirl
Jul 31, 2010 12:16 PM
tattoo13
Aug 29, 2008 06:57 PM
tattoo13
Jul 7, 2008 04:56 AM
