Front end wobble
Old May 29, 2012 | 07:51 AM
Mike650's Avatar
Mike650
if you have spoke wheels, check the spokes on the back wheel and make sure their not loose. i was getting a bad wobble because mine were loose in the back. tightened them up and was good to go.
Old May 29, 2012 | 08:25 PM
who...me?'s Avatar
who...me?
No spokes on the bob, tires look good. Looks like the fall away is the first place to start. Thanks to all for the insight.
Old May 29, 2012 | 10:08 PM
sharkey's Avatar
sharkey
Had my bike set at the dealers for fall away and it was worse than before...would start to wobble on fast downhills when I backed out of the throttle...not nice. Spoke to a tech instructor I know and he said he felt the factory spec was on the loose side; try 1/8 turn more on the neck bearing adjustment...bingo; cleared up! (That's AFTER you are sure eveything else is OK, of course)
Old May 30, 2012 | 08:44 PM
who...me?'s Avatar
who...me?
hmmmm, fall away is spot on at 3.25 inches, no cupping, rear tire in alignment. I assume if it was a tire balance issue I would notice it at 60 - 70. I guess I'll keep looking.
Old May 31, 2012 | 08:54 PM
punkmxcn's Avatar
punkmxcn
what if you're noticing it at 20-25mph but seems to go away when you apply front brakes???
Old May 31, 2012 | 09:28 PM
INJEKTER's Avatar
INJEKTER
fall away adjust i would think
Old Jun 1, 2012 | 11:43 AM
Low:Gary:Low's Avatar
Low:Gary:Low
At that speed aerodynamics can be a cause too, try pivoting your mirrors while riding see if it goes away. Windshield?, try shifting it around.
Old Jun 1, 2012 | 03:19 PM
lo-rider's Avatar
lo-rider
It's not caused by aerodynamics.
Old Jun 1, 2012 | 04:16 PM
BlockHead96's Avatar
BlockHead96
Change that front tire! Mine did the same thing, the stock tire is a POS.
Old Jun 1, 2012 | 04:52 PM
trip20's Avatar
trip20
Probably checked, but just in case... Low tire pressure can cause a wobble.
ringer1969
2014-2024 Touring Models
Sep 2, 2017 11:19 PM
Pmariner
Mar 8, 2016 06:21 PM
les63
Nov 11, 2009 08:11 PM
Capt O
Jun 19, 2009 01:07 PM
"catfish"
Jul 17, 2008 12:55 AM
