True Track Install ?
Old May 30, 2012 | 07:04 PM
MJGomz's Avatar
MJGomz
Default True Track Install ?
Installed the front True Track stabilizer on an 09 Dyna with no problems. I do not have the rear mounting bolt provided by True Track. Has anyone installed the rear with the stock bolts instead of using the provided socket cap bolts? Or does anyone foresee this being a problem? I don't have the rear bolt and would like to install it when I get home from work tonight. The only difference I could see is that the provided bolt might be a little longer. Thanks.
Old May 30, 2012 | 08:29 PM
O-Town D's Avatar
O-Town D
The stabilizer bracket is pretty thick (almost 1/2"); possible you'll get enough "bite" using the stock bolts but it would be close. If it were me, I would stop off at the local hardware store and get longer bolts just to be safe - sure wouldn't want to have to redo the install later down the road. The bolts are 3/8" coarse thrd, but I forget the length (my OEM bolts are in a jar mixed in with a bunch of others and I don't know which are which). TT is a sponsor here, you could probably ask them for more specific info.
Attached Thumbnails True Track Install ?-157496-o-town-d-albums-37195-tt-20-30-install-picture153040-tt-rear-stabilizer-installed-viewed-.jpg
Old May 31, 2012 | 12:22 AM
MJGomz's Avatar
MJGomz
Perfect. Thanks for that. Yea I figured I'd just pick some up before I pulled the stock ones but couldn't find what size they were. I figure I can take a good guess on length.
TexasMotorcycleRider
Milwaukee Eight (M8)
Jan 2, 2019 07:31 AM
monster715
May 17, 2014 04:23 PM
ardiver
Jul 26, 2012 08:18 PM
KrakkyDoo
Air Suspensions
Apr 27, 2012 06:29 PM
Rabid
Aug 10, 2009 07:34 PM
