Air Suspensions All you Air Ride Suspension Owners can discuss your Rides here
Shotgun ?
Old Apr 26, 2012 | 09:38 PM
KrakkyDoo's Avatar
KrakkyDoo
Default Shotgun ?
Do I use both bushings on the front bolts? One on each side of the frame? I assume I use the bolts that came in the shotgun.
Old Apr 26, 2012 | 09:56 PM
NC D'LUXE's Avatar
NC D'LUXE
I only used the front frame side shock dampeners. 1,700 miles and no issues that I'm aware off. Suppose I could have misunderstood the instructions, dunno.
Now you have me curious. If I don't go on a ride this weekend I'm going to have to put her on the jack and see if I can refresh my memory on why I didn't use the back side.
Old Apr 26, 2012 | 10:05 PM
Kowan's Avatar
Kowan
I used both bushings.
You won't need the stock washers on the rear bolts.
I made the mistake of putting them on and the bolts only go in so far.
So I had to remove the bolts to get the washers that made a nice dinging sound bouncing around loose.
Old Apr 26, 2012 | 10:13 PM
NC D'LUXE's Avatar
NC D'LUXE
krakky give it a shot with both front and rear.
Like Kowan said too, I made the same mistake and installed the washers on the back mount and they aren't needed, the rear side bolts that bolt the shock to the swingarm boss, aren't suppose to (and won't) go tight against the shock body on the back mounts. It's designed that way so you don't damage the rear shock bushings is what I was told by JD.
Guess instead of waiting until the weekend, tomorrow night I'm removing those dinging washers and am going to try and install the rear side of the front dampeners. Can't hurt to have them in. I'm thinking I didn't have room for them on the original install, but I may need to raise the swingarm more when you rotate the shock body up.
And yes, you'll use the 2 bolts supplied with the kit for mounting the front.
Old Apr 26, 2012 | 10:20 PM
NC D'LUXE's Avatar
NC D'LUXE
This is copied out of the instructions. I guess I may have overlooked the section that is underlined.
D. Make sure rubber shock dampeners are positioned on front frame mounts. Raise swing arm so that shock body will clear frame as you raise shock body into horizontal position. Now lower swing arm allowing shock body to rest slightly on dampeners. The two supplied 12 millimeter bolts can now be inserted along with the flat and lock washer. Do not lock tite threads. Now torque all 4 fasteners using a ž box end.
Old Apr 26, 2012 | 10:27 PM
NC D'LUXE's Avatar
NC D'LUXE
Also, just checked my inbox and another member was asking the same question, and JD called him back and confirmed that yes, use both the front and rear dampeners on the front mount. Sorry for any confusion.
Old Apr 27, 2012 | 06:25 AM
Blk and Chrome's Avatar
Blk and Chrome
I used both when I did mine. now get them on and post the pics...lol
Old Apr 27, 2012 | 07:26 AM
KrakkyDoo's Avatar
KrakkyDoo
Thanks for the help guys. I am going to give putting them on myself a try sometime in the next couple days. I did the apes myself so I think I can manage the shock.
Old Apr 27, 2012 | 10:00 AM
tunaman's Avatar
tunaman
YOU CAN DO IT!!!
And you'll be glad you did!
Roger
Old Apr 27, 2012 | 06:29 PM
NC D'LUXE's Avatar
NC D'LUXE
Guess some more frequent pre ride inspections are in order! Yes, both bushings (dampeners) are needed.
Took about 5 minutes after getting her up on the stand to install the backside bushings and the ride feels better (at least in my head it does LOL).
Apparently I bottomed out on the frame rail and never really noticed so I guess that also says something for the ride quality of this shock system.
zigzag
11
Jan 23, 2017 03:41 PM
liamw76
Jan 18, 2015 02:36 AM
bobbyjoes
Jun 21, 2014 07:28 PM
monster715
May 17, 2014 04:23 PM
m i k e
Sep 10, 2011 09:29 AM
