shotgun shock install?
Old Jun 16, 2014 | 05:47 PM
bobbyjoes's Avatar
bobbyjoes
Default shotgun shock install?
hi, just orderd my shotgun shocks,is there anything hard about the install,or the directions pretty straight forward,any other advice or pictures of install ,thanks
Old Jun 16, 2014 | 06:09 PM
Softail HA's Avatar
Softail HA
Take your time, and it is a pretty easy install, spend the time to route your wiring properly, and I would suggest cutting your air hose to fit. Everyone has a different way to loosen the shoulder bolts, I left the bike on the ground took a closed end wrench and a rubber mallet , calmly tapped each side for about 5 minutes they came off easy.
Old Jun 21, 2014 | 05:07 PM
bobbyjoes's Avatar
bobbyjoes
well i started today to remove old shocks,got the rear shoulder bolts out,wasnt bad at all with the rubber mallet,take a break and then go try the front,they say if shock does`not clear frame knock front sleeves out ,never took shocks off before ,any advice here ,2004 heritage,thanks
Old Jun 21, 2014 | 06:06 PM
Village Idiot™'s Avatar
Village Idiot™
Are the front bolts undone? The only thing that should hold it once all the bolts are out is the swing arm. Put a jack under the rear tire and pump it up so that it clears.
Old Jun 21, 2014 | 06:35 PM
bobbyjoes's Avatar
bobbyjoes
no front bolts are not out, if i turn then the hole back of shock turns that was hooked up with shoulder bolts,should i have taken front out first,thanks
Old Jun 21, 2014 | 06:47 PM
Jakerz00's Avatar
Jakerz00
The front shock bolt has flats on it for a wrench so you can keep the shocks from rotating when removing the front nuts. I want to say it was a 9/16.
Jake
Old Jun 21, 2014 | 06:59 PM
J.D.1's Avatar
J.D.1
Former Sponsor
Default Use 11/8th open end wrench
The shock would turn even with rear shoulder bolts still on. Use open end wrench on shock lock nut , and shock will be stabilized while you remove front nuts. JD
Old Jun 21, 2014 | 07:28 PM
bobbyjoes's Avatar
bobbyjoes
ya i figured it out ,thanks JD,put new SS on tomm,thanks
Delta
May 20, 2020 05:53 AM
liamw76
Jan 18, 2015 02:36 AM
billvaughn
Jul 21, 2012 07:26 AM
KrakkyDoo
Air Suspensions
Apr 27, 2012 06:29 PM
Johnny 5
Apr 8, 2012 09:27 AM
