Key Idiot light on
Old Jun 4, 2012 | 11:58 PM
JVDeuce's Avatar
JVDeuce
Default Key Idiot light on
My "key" red idiot light on the speedo is on...the bike seems to run just fine. Any ideas? And, should I take it in to be checked out?
Old Jun 5, 2012 | 07:52 AM
hellbob37's Avatar
hellbob37
You put any LED lights on?
Old Jun 5, 2012 | 01:09 PM
gilnbec's Avatar
gilnbec
Are you turn signals working? If your wiring is messed up that light will come on. Check the turn signal wiring under your rear fender to be sure they are in their retaining clips.
Old Jun 5, 2012 | 03:53 PM
bobnehoc's Avatar
bobnehoc
Have you checked for any codes?
Old Jun 5, 2012 | 09:01 PM
JVDeuce's Avatar
JVDeuce
Thanks guys for the input......Yes, I do have LED turn signals and rear light. They are integrated into an assembly that is mounted at the rear axle. checked the wiring and it seems to be fine. Attached is a photo for reference.
I hate being the newbie kick starter...........
Old Jun 5, 2012 | 09:43 PM
DonN's Avatar
DonN
Yes, that is what is causing the problem. You would need a add a resistor to the turn signal. I just ignore the red key light.
gmorgens
Aug 23, 2021 06:13 AM
Fblo1690
May 14, 2019 07:28 PM
slipvayne9278
Apr 25, 2019 08:58 AM
wjfisk
Feb 27, 2014 06:21 AM
DA ROOSTER
Oct 16, 2006 03:45 PM
