Progressive Drop in on a 2010 Wide glide
Old Jun 8, 2012 | 05:13 PM
markkoby's Avatar
markkoby
I did mine a while ago and I think the wide glide need longer spacers.
Did you measure the stock shook length before installing spacers?
How much did you want to drop the front end?
With the spacer you are using now, how much was the drop? If you want to raise or lower more use the spacers you have and make new ones by cutting longer or shorter.
I also remember that there was a minimum you are aloud to cut which was written in the instruction.
Old Jun 8, 2012 | 09:07 PM
gphil12873's Avatar
gphil12873
I didn't measure but I searched some post and saw where they cut them 1 1/2" so that's what i did. The instruction kind of vague cause I didnt know if you installed at the recommended length would there be a drop or not. But I can tell ya don't go to 1 1/2" It was horrible. I lowered the rear 1" and right now at 2 1/8" its looks good. If I had to start I would start in the 2 1/2 to 2 3/4" range cause I think there is a little more improvement over the way I have it now. If you want to raise it you make the pieces longer...Lower it cut them shorter.I think the instructions say 3 1/4 inches and they give you a recommended amount to go shorter and longer. The pieces that come with the kit are 3 1/4" long. But I do not know if you used without cutting what the drop would be....I searched and searched and couldnt find what I was looking for about this kit. It only takes about 10 minutes to change them out and that includes the time to cut the pieces so I say just play away and get it the way you want it.
Old Jun 9, 2012 | 05:00 AM
markkoby's Avatar
markkoby
I had same problem, instructions not very helpful. When I did the first cut I was way to low. Because I measured the shocks before I had a base point. If you are happy at the height now ride for a few weeks because the springs will settle and you may have to make a new set of spacers. I had to do it three time but all is good now. I lowerd my rear one inch and front 1.5" because I installed a 21" wheel, stance is good now.
Old Jun 9, 2012 | 11:33 AM
AllenW's Avatar
AllenW
So it sounds like your saying the longer the spacer the more pressure is on the springs, so the bike would sit higher..more pressure on springs means less travel before springs hold the weight of the front end?
Does that make a stiffer ride though?
I have enough spacer in mine that I can with a lot of effort get the caps back on, I also have a pretty stiff ride that way, much more than the stock springs.
I'll have to check oil level again, but I'm wondering if I take some of that preload out, will the ride get a bit smoother??
Maybe a lighter weight fork oil ??
tia
Al
Old Jun 9, 2012 | 02:30 PM
gphil12873's Avatar
gphil12873
tia
Al
Just from my experience the shorter spacer didnt ride well at all. Like rock solid with no movement. Put the longer spacer in there and I guess it has something with preloading the spring. Cause you will have to put pressure on the Fork Caps to get it back on. Now it does ride more firm than stock..but put a few hundred miles the way I had it and then put a longer spacer in there and wow...it will make you think you put a set up in it...
Junior_co
Mar 11, 2018 07:23 AM
HarleyBob52
Dec 26, 2012 07:53 PM
cdinsmore_16
Dec 30, 2011 04:00 PM
helenecillie
Feb 11, 2011 08:27 AM
ehc0720
Feb 4, 2008 06:19 PM
