CEL on then off at start up
Old Jun 5, 2012 | 11:37 PM
01ragtop's Avatar
01ragtop
Default CEL on then off at start up
I did a search, but I am mobile and I only found a few older threads that kind of just trail off.
2006 Wide glide. 25,000 miles.
After I start the bike, the check engine light goes out then comes back on for about 10 seconds, then goes back out. The code is P0373. CKP sensor intermittent.
The bike runs great, but I figure it's only a matter of time before it doesn't. Any ideas? Should I just replace the crank sensor now? Thanks all.
Old Jun 6, 2012 | 05:09 AM
maddghost's Avatar
maddghost
Since it is an easy job and the part not too expensive I'd guess that may just fix your intermittent prob.- Ya
Old Jun 6, 2012 | 10:11 AM
Scuba10jdl's Avatar
Scuba10jdl
Agreed, replace the CKP.
Old Jun 9, 2012 | 02:55 PM
01ragtop's Avatar
01ragtop
Okay, this morning I replace the CKP, and the CEL is still doing the exact same thing. I checked the connections on the plug and they look okay.
Old Jun 9, 2012 | 04:59 PM
desertrat702's Avatar
desertrat702
if you have a stored/historical code the light will turn on then turn off, you have to clear the code even though you replaced the part. i set a coil code on my sporty when i cranked it over with the coil disconnected and the cel stayed on till i i took the time to clear it.
Old Jun 9, 2012 | 06:25 PM
01ragtop's Avatar
01ragtop
Thanks, I should have known that. I had to reset mine once because of a broken wire on the front injector. All is good now.
theCoach
Jun 12, 2018 11:33 AM
Ben Marantan
Jan 31, 2013 11:38 AM
cgrnh
Aug 19, 2012 07:06 AM
louthestar
Aug 22, 2011 11:29 AM
calacha
May 31, 2007 07:34 PM
