octane 91 per manual?
Old Jun 18, 2012 | 04:50 PM
Badknee's Avatar
Badknee
2nd Gear
Default Non ethanol gas
Do a search in Google for stations that sell pure gas (non ethanol). Usually only available in 93 octane. If you think about the bikes mpg, the price is small.
Old Jun 18, 2012 | 05:10 PM
rubberfrog's Avatar
rubberfrog
Your bike was designed to run on the ethanol blend, so don't worry about it.
Old Jun 18, 2012 | 05:14 PM
missedem's Avatar
missedem
maybe so but id take non ethanol gas over ethanol gas anytime I have a choice. We get non - ethanol 93 here where I live and it runs fantastic in bikes. Unless I cant find it .. non ethanol for me. Bikes will tolerate ethanol ok but its not great for them. If you do use ethanol make sure you don't use any blend over 10 % . that will screw up your bike.
Old Jun 18, 2012 | 05:54 PM
sicpup's Avatar
sicpup
Originally Posted by 02LowRiderFla
My local station has 93 octane premium whuch contains up to 10% Ethanol. They also have 90 octane with no Ethanol added (it's near the ocean and people fill there boats up there). Which is better for my bike?
everything here is a 10% blend.. alcohol is combustable, it effectively adds to the ability to reduce detonation/increase octane.. that said the byproduct of burning it is water/moisture (if memory correct) and its EXTREMLEY caustic.. 10% is max auto mfg's reccomend. oh.. and it wrecks MPG.. big time
DO NOT add any form of alcohol to any fuel..
not sure about EPA and boats.. i would do much research first.. the catalysts and O2's may not like..
if you want high octane look at jet A or some sunoco race gas..
the real deal is if its not pinging your are fine.. in street/race motors in the past.. i would start out w/ super high octane then back down to the point of preignition/detonation.. thats where the car would make the most power all variables (timing/temp etc) taken out..
i have a diatribe on an old *** revived thread: simply put.. power out put is related to air in, fuel in, and the ability to control combustion via octane/quench/timing/fuel volume whatever. it all works together
that said.. being aircooled is a whole different amimal why do you think VW/porche killed the aircooled platform.. wait is anyone air cooled any longer? aircooled is NOT forgiving.. get the EPA involved/catalysts/computer control and your right on the edge of what is economically viable regarding longevity of said motor and said design..
but hey.. thats why i like the dinosaur.. wish it was carb'd tho..
my 2 cents
sicpup's Avatar
sicpup
spot on
Old Jun 18, 2012 | 09:16 PM
Mr Vegas's Avatar
Mr Vegas
1st Gear
Realize that just 'cuz the sign says "Sunoco" or "Shell" or whatever, it doesn't mean that it has to be Sunoco or Shell or whatever at the pump.
Old Jun 18, 2012 | 10:03 PM
patrickd's Avatar
patrickd
What would the better choice be 93 octane with 10% ethanol or 91 octane with no ethanol?
Old Jun 18, 2012 | 10:18 PM
Highhorse78's Avatar
Highhorse78
91 without ethenol.
Old Jun 18, 2012 | 10:29 PM
Island Hog's Avatar
Island Hog
91 without... if I try 87 I get decell popping and even backfires btween 1st. to 2nd. shifts!
Old Jun 18, 2012 | 11:06 PM
lh4x4's Avatar
lh4x4
I have run over all the mountain ranges in this continent, through Death Valley and the Desert South West several times.
All on 87 octane and never any pinging.
If a bike pings on 93 octane it needs a carbon cleaning or is being lugged.
HD recommends 91. But our nanny government requires that all engines be able to run on 87.
It's your bike put in it what you want.
