octane 91 per manual?
Old Jun 19, 2012 | 08:27 AM
jakenok's Avatar
jakenok
I do notice better mileage with 100% gas. That being said, I don't notice a difference between 87 & 91 whole gas. No pinging ever.
Old Jun 19, 2012 | 02:53 PM
patrickd's Avatar
patrickd
91 octane without ethanol is better.
Thanks all.
Old Jun 19, 2012 | 04:27 PM
mcw999's Avatar
mcw999
Use what works for you. In my limited experience fuel injected motors seem to compensate for low octane better than carbed bikes. I use highest I can get, partly for better mileage and range. That said many times I had to use 87 or even 85, as nothing better was available. In remote areas one has to take what one can get. Noticed that mileage suffered, butt dyno indicated that performance was off a little too. But it ran!
Old Jun 20, 2012 | 06:17 PM
blueridge's Avatar
blueridge
looks like I will have to get the octane 93 gas. We do not have octane 91 here...I thought we did. So I guess I will jump up to 93 and see how it goes. Thanks for the chime in.
Old Jun 22, 2012 | 08:37 PM
rooster02's Avatar
rooster02
FYI for those that ride in and through the state of Arizona; all the gasoline in the Phoenix area comes out of the same terminal and tanks, a central distribution terminal, no matter the name brand. 91 is about the most you can find in this area as there is no refinery in the state of Arizona. The majority of the gasoline is piped into the state from El Paso.
Old Jun 22, 2012 | 08:48 PM
Mike Horrell's Avatar
Mike Horrell
Originally Posted by sicpup
if you want high octane look at jet A or some sunoco race gas..
Crap. Pure crap...
Jet A is a form of kerosene, not gasoline.. Jets burn low grade (but very
highly processed) fuel because it doesn't make any difference to them
as long as it burns. If anyone ever put Jet A into any form of internal
combustion engine, it would friggin' DIE..
Old Jun 22, 2012 | 08:55 PM
Mike Horrell
Like Blueridge, above, I run 91 whenever I can but I've also used 87
in Death Valley or other remote areas cuz that's all that was available.
I've only gotten very minor, barely detectable pinging once on one tank
of gas in very hot temps near Sedona, AZ. Just dropping down a gear
and letting the engine run a bit freer stopped it. And that was on 91 octane.
Old Jun 22, 2012 | 08:56 PM
maddghost's Avatar
maddghost
regarding fuel vendors the only difference for the most part is the additive packege to the base fuel stock...
Right because the fuel is all the same. higher octane is for high performance engines and it's purpose is to reduce engine knock. 100 octane is a needless expense on a harley engine, stage 1,2 3, or 4
@ o leary17 it takes a couple of tanks of the same mixture for the ecm to make the adjustments. It isn't something you will feel right away.
Old Jun 25, 2012 | 11:40 PM
ThePhotog's Avatar
ThePhotog
1st Gear
I run 93 of anything that's considered top tier gasoline.
http://www.toptiergas.com/
Old Jun 25, 2012 | 11:53 PM
soft 02's Avatar
soft 02
Originally Posted by Mike Horrell
Crap. Pure crap...
Hell it would have a hard time getting past the injectors!
